408 parts are on order :)
High on diesel fumes
Ordered my stuff today
Pistons are custom, so that may take 2-3 weeks, so hopefully I'll be up and running in a month or so.
Crank Callies DragonSlayer
Main studs ARP
Rods Compstar
Rod bolts ARP 2000
Pistons Diamond 11576 (in-bore -28cc dish - custom cut for 1/16, 1/16, 3/16 rings
Piston rings Total Seal MS3690-35
Oil pump Melling stock replacement
Timing chain LS2 timing set
Cam bolts ARP
Camshaft Vinci Trucker (already have this one - temporary till FI)
Lifters SDPC LS2/LS7 style
Pushrods Hardened
Rocker Arms stock
Valve springs dual
Retainers titanium
Valves Stainless
Heads WCCH stage 2 317's (74cc)
Head gaskets Cometic .03
Head bolts ARP studs (make sure I get 12 point)
Intake manifold SSR manifold
Fuel injectors 42#'ers
Crank balancer bolt ARP
Main studs ARP
Rods Compstar
Rod bolts ARP 2000
Cam bolts ARP
Pushrods Hardened
Rocker Arms stock
Valve springs dual
Retainers titanium
Valves Stainless
I'll sell you the supercharger that won't fit under your hood!!
Or a crankshaft with stripped snout threads!!
Or a good crankshaft out of a 5.3!!
Or....ummmm.....that's about all that's left!
Originally Posted by RedXtacy
damn so are you going with a bigger supercharger now?
Found metal shavings in the pan, which ended up being nothing, but I pulled the cam out of it to check the cam bearings, and when I went to reinstall the balancer pulley I stripped the threads out of the crank. Since it would need to be pulled apart to balance the rotating assy again with a new crank, I decided it was time to just go ahead with the 408 that I've been wanting anyway. At least the 6.0 lasted 6 months!!
Criss Engine and Machine in Tucson is going to do the machine work for me. I have a friend in Tucson too who is an engine builder too so that's the plan for assembly.
LOL thats funny. If you need help chris just give me a call.
Sounds good Brett. It'll be about a month before I'm ready to go again. Hey....do you know anything about MKII Toyota Supras? I'm doing a head gasket swap on one right now. Want to help me put it back together tomorrow morning?
Once the big stuff gets sold from the firebird I need to pick up a DD then I have to see what funds allow for. I think I might go the 402 LS2 route, not sure if i want the extra weight of the iron block.
Chris
Chris
