Manual Transmission - Spec Clutch Users What Master Cylinder?
wicked z28
11-22-2006, 12:01 PM
Like The Thread Reads What Master Cylinder Are You Guys Using,i Have The Spec 2 With 01- 02 Upgraded Master And Slave No Drill Mod.it Drives Perfectly Fine On The Street But When Im Wot And Trying To Speed Shift,power Shift I Cant Get In Gears.so My Question Is Do You Think The Drill Mod Will Take Care Of This,and Since Im There Should I Upgrade To A Better Adjustable Master Etc And Which Brand.
wicked z28
11-22-2006, 05:50 PM
Anybody ?????
CW00BlackTA
11-22-2006, 08:14 PM
I've run my stock 2000 part since the car was new with no problems. I'm running a Spec 3i clutch with the 02 slave. Make sure your fluid is clear and the lines are insulated from heat. I change the fluid in my reservoir once a month or so.
98 SNAKE EATER
11-23-2006, 10:01 AM
Spec Stage 3 X-Pad
288 Slave (w/Spec Shim)
277 Master
No Drill Mod
Rubber in 4th :drive:
http://video.google.com/videoplay?docid=965411734155766185&hl=en
Aztek T/A WS7 (http://community.webshots.com/user/98snakeeater-reg) & 70 RAM AIR IV T/A (http://community.webshots.com/album/24092276OJKrbnMEGT)
Moderator (www.ls2.com) @ LS2 (www.ls2.com), FAST LS1 (www.fastls1.com), FUELSLUT (www.fuelslut.net),
The F-Body Hideout (www.f-bodyhideout.com), LS1Turd (www.ls1turd.com) & ChopperForums (www.chopperforums.com)
i was having that same problem. make sure that you install the shim!!!
wicked z28
11-24-2006, 12:38 PM
The Shim Goes Behing The Master Cylinder Or Were, And Were Do I Get One From.
98 SNAKE EATER
11-24-2006, 04:16 PM
No, the shim goes behind the slave cylinder....
Just unbolt it and place the shim behind it before bolting it back in place....
Umm, Spec usually sends a shim out with their clutches, but if you didn't get one, I'm sure they'll send one out....
Rick
bigdsz
11-24-2006, 04:35 PM
It's very important to do the drill mod and if you have headers you should shield the line going from the master to the bell housing. I wrapped my line with a reflective silver asbestos like cloth that I got from a parts store.
wicked z28
11-24-2006, 05:57 PM
I Wonder If You Can Buy The Shim Or Something Locally.
98 SNAKE EATER
11-24-2006, 06:11 PM
Might wanna contact East Side Performance :cool:
Back when thechef talked me into getting a Spec 3 X-pad a couple years ago, he said he had a stack of them at the shop that they used for coasters lol
It wouldn't take much to make one youself, but if you're gunna go through the trouble of pulling the trans to install it, you might as well wait for the correct one from Spec....
Rick
wicked z28
11-25-2006, 02:03 PM
So I Have To Pull Out The Trans To Do It Im Just Looking To Do The Drill Mod And The Shim.
98 SNAKE EATER
11-25-2006, 04:04 PM
Yes, the shim goes behind the slave cylinder which is located in the bellhousing, so you'll have to remove the trans or at the very least unbolt it and slide it back to gain access to the slave....
For the drill mod, you'll need to remove the line at the master cylinder....
I've heard of a few doing this without removing the master, but I've found it to be easier to just pull the whole thing out first....
Rick
1BADAIR
11-26-2006, 08:12 PM
I have installed a few x-pads
All of them slipped or had a very high pedal with the shim installed
Had to remove them all
wicked z28
11-27-2006, 12:29 PM
I Just Have The Spec Stage 2,thanks Guys For All Your Input
BR1060
11-27-2006, 02:28 PM
OK... So I have gone through 4 clutches, the Spec stage 3+ was before I realized that you HAVE to do a Drill MOD.. IT burned out the clutch and I only got 3000 miles on it. As far as the Master is concerned, I stuck with the stock and performed the drill mod which makes everything so much easier, not to mention stop and go traffic where depressing the clutch every other minute. I also went through a Centerforce clutch, once again, it only lasted for 3000 miles but that was an entirely different issue. THe point of the shim is just to create space so that you don't have to depress the clutch fully - you can create one on your own with metal pieces as long as it holds up and can take that kind of pressure. My advice, perform drill mod -- because it will save $$ in the long run!!
wicked z28
11-27-2006, 05:03 PM
Thanks For Your Advice Will Do.
ls1amit
01-03-2007, 11:07 PM
Spec Stage 3 X-Pad
277 Master
No Drill Mod
whats the 277 master?
badpewter-z
01-04-2007, 11:58 AM
stock master with mine, alone with almost all the clutches ive helped put in. few i know that had the adjustable went back to stock and were alot happier too ;)
kookamunga
01-04-2007, 08:17 PM
RAM adjustabe matser cylinder
SPEC Stage 2
Fidanza Aluminum FW
Installed shim behind the slave cylinder
BTW I have a spre shim if anyody wants one
