Will Magnaflow for 95 Z28, fit my 98 Trans Am?
I tried to do a search and came up short so I appologize ahead of time if this is a double post, but I am looking for a Magnaflow catback for my 98 Trans Am. I found a cheap used maganflow off a 95 Z28 and was wondering if this would fit my car or would require modification? Thanks everyone!!
everything should fit, my brother used his SLP firehawk exhaust off his '96 Ram Air Formula on his '01 T/A and it fit fine. connections should be the same and the body and axle routing didn't change from the LT1 to the LS1, so you should be fine.
I am sure others will chime in if I am wrong...
