What air/fuel ratio is considered too lean?
Old 11-23-2006, 10:15 AM
damon_Z's Avatar
Default What air/fuel ratio is considered too lean?
from my post below,
'02 A4 Z28 w/PTB dynoes@298...after SLP lid, dynoes@303...after SSRA2, dynoes@318!,
my air/fuel ratio of 14.1 is considered lean. Is my air/fuel ratio lean enough so that I shouldn't run the car in the quarter without first getting a tune to richen out? or am I okay? If so, then what air/fuel ratio is considered too lean so that there's a risk that the engine can detonate? Thanks in advance for the info.
Old 11-23-2006, 10:46 AM
PLucas's Avatar
14.1 is lean. Is it getting any knock?
Old 11-23-2006, 02:22 PM
damon_Z's Avatar
I don't know. When the car was bone stock, the air/fuel ratio was at a factory rich 12:1. The ported throttle body and the SLP lid leaned it out significantly.
Old 11-23-2006, 04:09 PM
5550racing's Avatar
Yeah, I was wondering what was too lean. I dynoed 320, 309 at 15.2 AFR!
I thought 14.7:1 is considered perfect.
Old 11-23-2006, 04:33 PM
sidewayz28's Avatar
14.7?!?!!?!?!?!?!?!?!??! are u serious?
Old 11-23-2006, 04:36 PM
Rhino79's Avatar
12.8-13.0 at WOT is your target, 14.1 is way lean. I set the WOT fueling around 12.5 around peak torque and lean it back to 12.8 after that.
Old 11-23-2006, 04:42 PM
cws T/A's Avatar
14.7 is idle or your cruise AFR '' Stochiometric ''
Old 11-23-2006, 05:16 PM
Tech Resident
ChocoTaco369's Avatar
i think you're overreacting. you did all those mods back-to-back, correct? the mods were thrown on and the car immediately hit the dyno, correct? if this is true, the PCM never got a chance to readjust. if you were to hit the dyno now that the car has been driven and has adjusted, i bet your A/F ratio would be significantly richer.
Old 11-23-2006, 05:26 PM
5550racing's Avatar
My bad. I read It wrong. I Guess I wasn't looking at WOT fueling. Holy ****. My car is wayyy lean at WOT then.
http://en.wikipedia.org/wiki/Air-fuel_ratio
http://www.knfilters.com/airfuelmonitors.htm
http://auto.howstuffworks.com/question257.htm
A gasoline engine burns gasoline in the presence of oxygen (see How Car Engines Work for complete details). It turns out that there is a particular ratio of air and gasoline that is "perfect," and that ratio is 14.7:1
Old 11-23-2006, 06:30 PM
damon_Z's Avatar
Yeah, that's what I was thinking.
Old 11-24-2006, 01:40 PM
Black Z28 M6's Avatar
This guy is right.12.8-13.0 is your target to get all the power you can.
3.0-5.9, 6.0-8.4, 8.5-13.0, 13.1-17.0, 17.1-19.0
Flooded,Way Rich,[U]Rich-Lean[/U],Way Lean, Engine damage
Old 11-24-2006, 01:43 PM
Flooded,Way Rich,Rich-Lean,Way Lean, Engine damage
Old 11-24-2006, 01:53 PM
TORCHD 02 TA's Avatar
thta is a good point anthony!
Old 11-24-2006, 04:31 PM
BrandonDrecksage's Avatar
choco is probably right sinc ethe ecu will learn after mods, but I'd get the car dynoed again, or some how figure out what the a/f is just in case, it'll probably be cheaper than killing the engine.
Old 11-24-2006, 04:33 PM
damon_Z's Avatar
Thanks for the range. It'll make me feel better when I'm at wide open throttle on the dragstrip.
Old 11-24-2006, 04:37 PM
damon_Z's Avatar
I know there is a risk of damaging the engine, but I also know that there are plenty of people out there who never gets dynoed, but just run with whatever mods they have on the dragstrip. I mean, have you ever heard of anybody damaging their engine just from running WOT with a ported throttle body, SLP lid, and an SSRA2? I'm going to take the risk tomorrow at Atco's annual winter wonderland.
Old 11-24-2006, 11:07 PM
i've heard of peopel blowing their engines with bullshit mods. its a rish. My friend had a mazdaspeed protege with jsut a coldair intake. Apparently the factory tuning was a little to lean and the intake killed it off. He blew the engine at the strip. It was under warranty and he took off the cai. friend in a 1g talon tsi awd maxing out the stock injectors ran to lean too because he was an idiot. Everyone takes a risk though(**** the guy in the next lane could spin out and hit you and insurance wouldn't cover it), i've raced my car with a lid and catback without know my a/f though, but i know my car is running rich because of the smell and slight cloud of black smoke in the upper rpm range. Whatever floats your boat though..its your car only difference between you and I is taht you know your way to lean.
either way, good luck, hope you trap that 110mph
Old 11-25-2006, 03:13 PM
mullenh's Avatar
and what are you using to do it?
Old 11-25-2006, 08:41 PM
Cheatin' Chad's Avatar
14.7:1 is considered chemically perfect under the right circumstances.
This is rarely (if ever) perfect for peak performance.
Old 11-26-2006, 02:55 AM
That's what she said...
TheBlurLS1's Avatar
12.8-13.0 is correct for WOT. 14.7 is correct for normal operation.
Your car is constantly trying to shoot for 14.7, to burn all the gasoline and recover all the energy, for maximum fuel economy. This, however, does not produce the most power. When the car senses over a certain throttle percentage at a certain RPM, it enters PE territory. PE stands for "Power Enrichment", which is simply a number that 14.7 is divided by and the computer then shoots for as the commanded AFR.
Technically, PE should be about 1.14, which would command us a 12.9 AFR, but we usually have to tweak it untill it's right.
14.7 is as lean as I'd go. Anything richer than that is "safe".
Damn I'm going off here....
And that's all I have to say about that.....
Quick Reply: What air/fuel ratio is considered too lean?
