need some explanation
Old 11-23-2006, 01:05 PM
z2envy's Avatar
Default need some explanation
Alright im looking at getting heads and cam for my 2000 camaro z28 from patriot performance and i just wanted to know what some numbers mean as far as lift and duration. I know a guy who had this setup on his ss and he said that it was pretty sick.
Heads:
2033 - Assy. 2.055"/1.57"/59cc - $1,295.00 pair
We use a new GM raw 035 casting.
Precision welded combustion chambers.
Heat treated to OEM specs.
5 axis CNC machined.
Hand detailed and assembled.
21-4N Stainless Valves
Bronze Guides
Patriot Gold .650" Dual Springs
Titanium Retainers
5 Angle Valve Job
Custom chamber sizes available
No core required
Cam:
8403 - 226/226 Dur. @.050 .585"/.585" Lift 112 LSA - $279.50
You guys think that would be a good setup? What else would be needed as far as replacing/upgrading?
I have no idea what all the clearances and lift/duration stuff means , if someone could dumb it down for me i would appreciate it. Thanks for your help. - Andy
Old 11-25-2006, 06:25 PM
slammedchevy's Avatar
i think that would be sick just need a good tune
duration is how long the cam keeps the valves open for,lift is how far the valve is opend
