What valve spings for g5x4 cam?
Old 11-23-2006, 09:17 PM
SPRAYED 01's Avatar
Default What valve spings for g5x4 cam?
Im thinking of swaping the old tr224 for a g5x4. Im running crane dual springs rated to .650 lift. Will that be enough of a spring? If so would i need to replaced them often or at all. How valve train friendly is this cam?
Old 11-24-2006, 12:47 PM
SPRAYED 01's Avatar
Anyone???
Old 11-24-2006, 12:57 PM
prostock_bigblock's Avatar
yes it well be enough.
Old 11-24-2006, 05:12 PM
purdueranger's Avatar
Comp 921 springs here. I was told to change springs every 25k miles. Make sure to let those springs warm up before romping on the car.
Old 11-24-2006, 08:13 PM
SPRAYED 01's Avatar
Purdueranger, Is that what LG said to do? Are the comp 921s a dual spring?
Old 11-24-2006, 08:20 PM
Thimble's Avatar
I'm running the PRC duals with the X4 in mine.
Yes, the 921's are duals, and yes, they are expensive. Those are what LG will recommend.
Old 11-24-2006, 08:46 PM
SPRAYED 01's Avatar
Thimble, how much are the 921s? Were you told that they would need to replaced after a certain amount of miles? Hows your drivability with the x4?Thanks
Old 11-24-2006, 09:28 PM
Thimble's Avatar
Comp 921's typically sell for around $550 for the kit from most of our vendors.
I had originally ordered them, but was in a hurry and TR didn't have them in stock, so I went with the $289 PRC kit instead (of which I've not heard anything bad about).
Either should be good for 25k+ miles with proper use depending on how hard you beat it. By proper use, I mean...let the car (and springs) warm up before getting on it. Your Crane duals should fine to use with this cam. The X4 is an XE-R lobed cam with just a little over .600 lift. (less than .620) It's a little harder on springs than your TR224 is, but your current springs should be ok.
Drivability with the X4 is quite good...although my install was just completed a few days ago, I'm currently on my way cross country, and put 750 miles on it today alone.. It's a big cam, and it has it's bad manners...but mine hasn't even been tuned yet, so that's saying something. The car is running rich, it surges and bucks below 1500rpm, and it has stalled a couple times when coming to a stop. All tuning issues that will soon be taken care of, but other than that, I love it and it gets around on the streets just fine. I have mine idling at 900rpm, and the lope is wicked.
With a good tune, no doubt the cam is 100% streetable.
Old 11-24-2006, 10:06 PM
let the car (and springs) warm up before getting on it. Your Crane duals should fine to use with this cam. The X4 is an XE-R lobed cam with over .600 lift. It's harder on springs than your TR224 is, but your current springs should be ok.
Drivability with the X4 is quite good. It's a big cam, and it has it's bad manners. Tuning issues that will take care of, but other than that, I love it and it gets around on the streets just fine, the lope is wicked.
Fixxed
mine idles at 900-950rpm. I don't have any surging below 1500 rpms. with stock heads, stock MAF, fast 90/90, and full exhaust I am maxing out the stock injectors.
Old 11-24-2006, 10:11 PM
Thimble's Avatar
Originally Posted by purdueranger
Fixxed
As I stated, mine is still untuned.
That makes a world of difference no doubt.
Old 11-25-2006, 08:06 AM
SPRAYED 01's Avatar
Thanks alot guys, sounds like what im looking for. As soon as my speed shop want to answer their phones im going to order one and set up a tune date.
Old 11-25-2006, 09:59 AM
Yes it does. I can't wait to do some simple upgrades this winter to squeeze a couple more ponies out of her.
