4l60e WHAT THE!!!
Old 11-24-2006, 04:49 PM
FASTCAMAROMAN's Avatar
Default 4l60e WHAT THE!!!
i have taken off everything all 9 bolts out of the transmission driveshaft crossmember you name it bolts from flywheel/convertor and it acts like the transmission is welded to the motor? any ideas?
Old 11-24-2006, 04:53 PM
LS1Tech Sponsor
performabuilt's Avatar
try wiggling it agressivly by had sometimes the bell kinda weilds to the dowel pins from corosion
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 11-24-2006, 04:55 PM
nikon1999's Avatar
another vote for dowel pins, if the tranny has been in a really long time they can get rusted/corroded in there pretty good, spray some pb blaster on those bad boys and let it sit
Old 11-24-2006, 04:58 PM
LS1Tech Sponsor
That stuff is good have used it many times we used to joke that it allmost turn the bolts out by itself lol
__________________
Call 888-744-6542
Old 11-24-2006, 05:44 PM
The know it all's know it all
Sean Collins's Avatar
GM heat valve lubricant on the dowel pins. Either that or use some PB blaster and let it sit overnight. I sometimes have to use a pry bar to wiggle the trans to get them loose.
Old 11-24-2006, 05:59 PM
slimcracka's Avatar
flathead between the block and tranny FTW
Old 11-24-2006, 08:50 PM
Mazzenger's Avatar
I had the same problem, I used a prybar to get it off the one dowel that was rusted.
Old 11-24-2006, 09:59 PM
SLowETz's Avatar
Another vote for previous replies. Don't forget anti-seize on the dowel pins when re-installing
Old 11-24-2006, 11:18 PM
1999Z28's Avatar
i've found that the best is take the plastic cover loose(one 10 mm socket) on the drivers side loose and get a big pry bar in there, seems to be the best place to pry. Its probably just stuck like everyone else said.
