Rattling, but why?
Rattling, but why?
Hows it going guys, awhile back ago a chambered muffler and cutout was installed in my 2000 Camaro SS. At first I thought it was the electric cutout causing the rattle cause when closed I didn't hear the rattle anymore and when open the rattle would come out from the cutout. I installed longtubes with ory recently and now I'm hearing the rattle now even when the cutout is closed. WTF? The rattling happens around 2k and rattles on deceleration but does not rattle at idle. At first I thought it was from the ory hitting the floorboard or tunnel brace but I fixed both by placing a heater hose/ hose clamp on the ypipe and removing the tunnel brace. But still, the rattling is still there.
I've done my searching and can't find my answer. Do you guys think its from the chambered muffler? I've read about baffles but can that happen from a chambered muffler? Man I feel like a noob, sorry guys but I need your help.
NOTE: My exhaust starts from the headers, ory, chambered muffler and then electric cutout.
Originally Posted by Asmodeus
probably the heat shield that is above where the catalytic convertors used to be.
Originally Posted by BayAreaSS
I have that same noise on deceleration out of my cutout. I dont know what the hell it is!!
Originally Posted by scof0elife
Its so annoying hu? maybe we can help eachother? Keep me updated on information and I'll do the same man. We'll get it fixed, we must
I think there was a guy that put spacers in between the cutout and the lid of the cutout and it made it sound better.
If i remember correctly his name was MannyZ28. He posted pics of it also.
I had a rattling sound that I found out was the O2's. I the O2's open and found that my O2's had a ceramic piece inside the metal case that had broken off. Then the exhaust tubing amplified the sound x10 making it a horrible rattle. I put in new O2's and the car is rattle free again. Try taking the O2's out and just shake them to see if they make noise. it could be the same problem I had or just a electronics cutout thing but just tossing that out as a possibility.
Yeah I was thinking of checking the o2, hopefully tomorrow I can check under the car to see what the hell is rattling. So I'll be looking for the heat shields and o2's, since I'm down there is there anything else I should look for?
i have the same rattle and it was the heat shield for the passenger side cat making the most nosie. I removed it and it helped but its still there, and ive tried putting rubber washers in between the heat shield and it didnt help at all
