biggest cam in AFR 62cc w/o flycut
Old 11-25-2006, 10:11 AM
Ls1Envy's Avatar
Default biggest cam in AFR 62cc w/o flycut
Is anyone running a bigger cam than a 228/230, 114LSA on AFR 205's milled down to 62cc. I don't want to flycut. Thanks, Nate
Old 11-25-2006, 10:18 AM
hesham's Avatar
you can withoun any problems
Old 11-25-2006, 11:30 AM
PREDATOR-Z's Avatar
According to louis at LGM, you can run a G5x3 (234/242, 114+4)
Old 11-25-2006, 12:32 PM
Ls1Envy's Avatar
I saw something on someone running the g5x3 on a 59cc 205. He must have used a gasket bigger than 040.
Old 11-26-2006, 06:55 AM
Ls1Envy's Avatar
So a Cam with less duration should clear.
Old 11-26-2006, 08:44 AM
PREDATOR-Z's Avatar
It is not that simple, meaning not only relative to durations. It is also relative to the VEs, where LSA and ICL play a major role.
Old 11-26-2006, 08:53 AM
beardWS6's Avatar
Sorry to jack you thread. But I`m wanting to go bigger with my cam also. My heads are ET 245`s 64cc. How big can I go if anyone can answer that. Thanks. Good post by the way. Thanks!
Old 11-26-2006, 09:27 AM
Ls1Envy's Avatar
Well let's just say a cam with duration and exhaust in the low 230's, under .600 lift and LSA's of 14. This should in reality should clear better than a 234/242 114.
My thing is don't want to lose a lot of torque down low, I want to go with something like a 230/232 or 230/234 on a 114. And still mill my heads to 62cc with a .040 Gasket w/ cutting
Old 11-26-2006, 10:43 AM
PREDATOR-Z's Avatar
Then just go with like a 231/234 111 and do not mill
You'll get better effect that way.
Quick Reply: biggest cam in AFR 62cc w/o flycut
