any ideas?...
Old 11-25-2006, 11:01 AM
01lowbird's Avatar
Default any ideas?...
Im working on a buddys 98 formula. he brought it to me barely running and to me it sounded like he popped a head gasket. i ran a compression test and every cylinder was 150+ lbs. the car is missing on cylinders 3,5,7,6. it has brand new plugs, i did a ohm test on the wires... all good, all coils are good. pulled the fuel rails and injectors, cleaned them and did some swapping of injectors. nothing changed so injectors are good. no broke valve springs, i didnt pull push rods but what i could tell seemed fine. posible for timing chain to jump or stretch and cause this... any thoughts would be appreciated
Old 11-25-2006, 03:52 PM
sickss228's Avatar
You should perform a leakdown test on all cylinders
