4L60E - Vibration in 3rd only...
Old 11-25-2006, 06:10 PM
Racer383's Avatar
Default 4L60E - Vibration in 3rd only...
I have a 99 TA with 124k on the clock. The car is stock except for a k&n and an SLP lid. Picked it up a few months ago so I am just listing all its bugs and putting a hit list together. First off, the transmission shifts and locks up just fine. However, I have noticed a vibration the comes in when the trans shifts into 3rd. The vibration goes away when it shifts into 4th and is not there in 1st or 2nd. I have noticed the vibration both when driving easy and when running it all out.
When I got the car, the transmount was busted, so I put a poly one in. At first, I thought this was the cause for the vibration, but I doubt it would only be in 3rd then. The vibration is noticable, but not severe at this point, though the faster you are going, the worse it is.
I know transmissions are fun to diagnose over the internet, but any ideas on what type of problem I may be looking at?
Old 11-25-2006, 06:16 PM
Has Unresolved Sales In Feedback/12 second club
notatruews6's Avatar
I have a 99 ta also, it has the same problem, i would check the front and rear u joints on the drive line, thats what fixed mine.
Old 11-26-2006, 01:20 AM
LS1Tech Sponsor
performabuilt's Avatar
I agree since I cant imagine anything that would cause a vibration in the transmission in third only
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 11-26-2006, 05:48 PM
Pontiacerator
RevGTO's Avatar
Do a search on "vibration" in this forum. There have been a few threads on this over the years. 3rd gear only - it may defy explanation, but it's pretty common. I have it.
Old 11-26-2006, 05:51 PM
slimcracka's Avatar
my car does it too...
Old 11-26-2006, 07:32 PM
dhdenney's Avatar
Reason being is that 3rd gear is a 1:1 ratio and everything in the driveline is turning at the same time. Any warpage or bad pinion angle will show up in 3rd.
Old 11-26-2006, 07:49 PM
Tech Resident
ChocoTaco369's Avatar
i have a vibration in my car in 4th gear when it's locked up at exactly 50 mph. i have no idea what the hell it is. 45 mph it's quiet. when i accelerate locked up from 49-51 i get a weird sounding rattle from directly under the console (so it sounds) and then it goes away. hate to hijack, but have any of you guys had this problem, too?
Racer383's Avatar
Thank you for all the replies. Sad as it sounds, I am glad I am not alone
Guess I will take a crack at new u-joints. I have re-done aluminum shaft that was slated for my 98, I guess I will give it a test in the 99 for kicks.
I was looking to put a stall convertor in but the vibration was conserning me.
Old 11-26-2006, 08:22 PM
LS1Tech Sponsor
Good luck sorry could not give a more definative answer
__________________
Call 888-744-6542
Old 11-26-2006, 08:40 PM
Racer383's Avatar
Thats ok, thats for any info. I was half expecting to hear, "yeah, mine did that then blow up". lol
I know I will be needing a new transmission in the near future, I just hope it gives me time to research what transmission I want...
Old 02-16-2010, 09:44 PM
LT1Formula007's Avatar
Wanted to mark this thread. I know it's old. LOL
I didn't realize that vibrations could occur in 3rd gear mainly b/c the trans. is at a 1:1 ratio. Makes sense though since everything will be turning together at the same rate of speed.
I guess you do learn something new everyday!
Old 02-16-2010, 10:03 PM
72blownvert's Avatar
Get rid of the poly mount.I have fixed a couple of cars by going back to a stock mount.
Old 02-17-2010, 11:38 AM
dhdenney's Avatar
LOL and I fixed some vibrations by doing just the opposite. My stock mount must have been shot.
Old 02-17-2010, 01:17 PM
ArkBird96's Avatar
Yep. Mine does the same thing, but intermittently. I'll be cruising at about 60 or so with it in OD and the TCC locked, then I'll punch it to make it downshift into 3rd. Sometimes it vibrates until it hits 4th, sometimes it doesn't. I suspect a bad transmission mount in my case as it is also doing other things to make me think the mount is shot.
Old 02-17-2010, 06:33 PM
dnkynrbk's Avatar
One thing to help is moving your Torque arm mount off your tranny and get a brace that holds it. If you drag race your car the torque arm puts alot of stress on your trans and poly mount.
Old 02-17-2010, 11:49 PM
^^^ That makes alot of sense... Thanks For the Tip!
Old 02-18-2010, 03:37 AM
SSdimension's Avatar
I think it would be your yokes from the driveshaft. When I changed my tranny it made that sound. I went back to see what was wrong. I saw the yokes and one of them was a tad of like the thickness of a quarter. I put it all the way down and the vibration stopped. 10 months go buy and I get it again. but this time it was the transmission mount. Its a two piece but I took out one of them installed a long bolt I bought at the hardware store and put like no bullshit 25 washers and a big *** nut and torque it all I could. Dont do this tho. I just thought I will put it out there. I was at the track when I encountered this problem so I was looking for an easy fix. gl
Old 06-15-2012, 08:44 AM
Wild Willy's Avatar
Anyone ever figure this out? My car has done the 3rd gear vibe since I bought it in '06. Worse under load, if you are on it hard, it shakes pretty bad. I have since moved the torque arm off the transmission, and replaced the stock steel driveshaft (came with the 2.73 gears) with an aluminum one off a B4C Camaro. No change- did GM screw up balancing them from the factory?
Quick Reply: 4L60E - Vibration in 3rd only...
