EGR removal
EGR removal
I know subject has been bruoght up many times ,but im still not sure about proper removal.Its a 99 TA M6 , I ordered A AIR/EGR kit from.ws6store.com i recieved 3 metal plates w/gaskets.I was under the impression the EGR pipe going into the intake was completly removed?am i wrong?the kit i recieved does not include anything to cover the intake,@installuniversity. it only shows it being cut 1.25 inch? Id appreciate any help fellows.
That's what she said...
You will be removing the EGR tube/solenoid from the engine bay completely. You'll need a 1-3/8" adjustable freeze plug to fill the hole, which you should be able to find in one of the stickies at the top of this section.
The "cutting the pipe" is for if you're leaving it in place. The block off plates are for complete removal. You will get the SES light for removing these things untill you get someone to tune the codes out.
