No start issue...
Old 11-26-2006, 01:08 PM
mshadow's Avatar
Default No start issue...
Car will crank and crank and not start. If I reset the PCM the car starts and runs fine...you can turn it off and back on. You let the car sit for a couple of hours it will crank and crank and not start back up till you reset the PCM.
Its not the crank sensor.
Old 11-27-2006, 10:16 PM
mshadow's Avatar
bump any ideas?
Old 11-28-2006, 12:26 AM
Closed ex-Sponsor Account
autotrix's Avatar
Define "reset" PCM. Not sure about the problem really, a scanner could help shine some light on the subject.
Old 11-28-2006, 06:17 AM
mshadow's Avatar
Pulled the PCM IGN and PCM BAT fuses.
Old 03-26-2007, 10:05 AM
mshadow's Avatar
Update...It was the ignition relay...
I did some searching on here and few people had similar problems....put a new one in and all set.
