Dynoed 407 with 3 psi on TTi kit
Old 11-26-2006, 02:22 PM
blackbird345's Avatar
Default Dynoed 407 with 3 psi on TTi kit
Well I finally got to the dyno and I wanted to see how the car was running before I added any more boost. So with 3 psi I managed 407 rwhp. I was a bit disappointed as I have H/C (10.8 CR) as well. The A/F ratio was around 12 is that ok? I have the PE set at .81 so I'm figuring I'll drop that to .78 and turn the boost up to 6 psi, will that work?
Old 11-26-2006, 02:29 PM
anarchy99's Avatar
your compression ratio is 10:8 without a turbo?
Old 11-26-2006, 02:40 PM
02Vortech's Avatar
i think thats what hes saying---- that a/f ratio is a bit lean for my tastes as well as what many people do- 11.3 to 11.5 is a safe a/f ratio- if its an N/A cam, and your still on the C/H tune then im sure there is plenty left in the set-up
Old 11-26-2006, 03:57 PM
SuperZ's Avatar
holyl crap how do you evan get 3psi!!! Ive never seen anything under 5psi
Old 11-26-2006, 04:28 PM
prostock_bigblock's Avatar
what r cam specs?
Old 11-26-2006, 05:54 PM
lol I just got the 3psi spring, I think its a bit above that, something like 3.5 psi really. Can is a Cartek cam, came with my Stage 2 h/c cam setup, I think it was called the "H" profile when I got it. I didn't know anything about cams back then so I just told them to send me what would give me streetable power. I should also state that I only dynoed 350 rwhp without the turbo ( but using headers) which is really low for a S2 H/C package. Anyway, I'm hoping to turn it up to 6 or 7 psi without blowing.
Old 11-26-2006, 06:05 PM
97BlackLT1TA's Avatar
Wow only 350 on a h/c car? seems a little low to me, maybe there is something else up with the car. Does it run ok otherwise?
Old 11-26-2006, 09:38 PM
Yeah runs ok but Cartek sent me a computer so it wasn't tuned on the dyno or anything....
Quick Reply: Dynoed 407 with 3 psi on TTi kit
