Head Install complete
Old 11-26-2006, 04:45 PM
blkbird's Avatar
Default Head Install complete
Well, after four gruelilng days of battling this task myself, I finally got the LS6 heads installed along with replacing the lifters. It started right up with no issues. The only thing now is that there is a small amount of coolant leaking from the damn front colant pipes going from head to head. Has anyone else ran into this problem and can it be fixed easily. I drove it home from my friends house (22 mi) and it has seem to stop a little. Im wondering if it will just plug itself up on its own in a couple of day. Well, at least the hard part is over...... It feels pretty damn good. I also replaced my motor mounts, they were shot. They just fell out of the clam shell......
EDIT: Is it normal for it to be smoking a little bit at idle. After I drive it there is no smoke?? I think I need to retune it.
Click here to see Video
Old 11-26-2006, 05:01 PM
Mssingkid's Avatar
Congrats!! You can try some High Temp silicone sealant (Think it's in a black tube). That should help keep the leak under control. I know some of the coolant tubes had some sort of washer type gasket(At least my 98 did), the new one that replaced it had a rubber gasket.
Old 11-26-2006, 05:02 PM
jermzz's Avatar
Did you use the gaskets, and were they put on the correct way for the water pipe? Torqued down properly?
Old 11-26-2006, 05:05 PM
blkbird's Avatar
I reused the gaskets from the other heads and I torqued them down pretty good. I will see how it goes in the next couple of days. I will probably just RTV it.
Old 11-27-2006, 05:37 PM
blkbird's Avatar
I figured out why it was leaking coolant. My dumb *** forgot to put the washer with the little gasket on it. I thought I had. They were still on the old heads. Well that was a quick fix and now the car is going strong!!!!
Old 11-27-2006, 08:19 PM
Long Beach's Avatar
Good job, it feels good dont it? If thats all that you forgot then you are dooing just fine.
Old 11-28-2006, 10:07 AM
blkbird's Avatar
It feels great knowing you did the job yourself and didnt **** anything up....
Old 11-28-2006, 10:14 AM
HAMRHEAD's Avatar
Congrats and enjoy the feeling of doing it yourself when you smoke another car!
Old 11-28-2006, 09:17 PM
jermzz's Avatar
Yeahh, that's the little thing I was talking about. Those things are easy to overlook. Good job
Old 11-29-2006, 07:40 AM
blkbird's Avatar
Thanks. I can believe I missed those things.
Old 11-29-2006, 08:50 AM
blkbird's Avatar
I added a vid. Let me know what you all think.
Old 12-01-2006, 06:30 PM
blkbird's Avatar
TTT for a question.
Old 12-01-2006, 11:59 PM
99C5Coupe's Avatar
Interesting setup you have, I would be interested to see a dyno graph. How much HP are you expecting?
Old 12-02-2006, 04:33 AM
DaddySS's Avatar
Excellent! Glad to hear it's working well!
Old 12-02-2006, 05:28 AM
Mssingkid's Avatar
Well after the initial start up, it's not uncommon to see smoke in the engine bay, but if it's coming out the back at idle, that's not good. Did you use a thread sealer/lock on the rocker bolts?? Most CNC'd LSx heads take away so much material that the rocker bolts are exposed in the intake runner. If you don't use a thread sealer you'll get oil that'll come into the motor from these points. This can lead to detonation etc. Car sounds good.. Not running around with open headers are ya?
Old 12-02-2006, 07:55 AM
blkbird's Avatar
These heads were not ported so the rockers arent an issue. I am not running open headers anymore. I just did that to have a little clip of it. Im thinking it might be that it needs a tune also. It is wasting a little more gas than usual. I just dont want this to become a big issue with my DD.
Old 12-04-2006, 03:10 PM
blkbird's Avatar
I hope to get as close to 400rwhp as I can. I will be happy with that.
