a/c delete pulley
Old 11-26-2006, 04:53 PM
ss97dml's Avatar
Default a/c delete pulley
anyone have any problem with it lining up? i had to shim mine out 1/4"!!! it shredded my belt before i noticed,of course it's real fun to take my 12rib s/c belt off to get to it
Old 11-26-2006, 05:22 PM
sleeperMULLET's Avatar
you probably have the wrong one, where did you get it from?
Old 11-27-2006, 12:35 PM
the_merv's Avatar
Yea, post a pic of it up..
Old 11-27-2006, 11:15 PM
Lethal Z's Avatar
No problems with the line up, just had to buy a shorter belt.
Old 11-27-2006, 11:31 PM
the_merv's Avatar
Shouldn't even need a shorter belt, it lines right up. Sounds like you might have the Gen III Pulley..
Old 09-17-2010, 01:48 PM
tscheu5452's Avatar
I had the same problem with the A/C delete pulley from Advance Auto. It's a piece (of ****) from China. Had to add washers on the back side of the bracket so it would align with the other pulleys.
Old 09-17-2010, 01:52 PM
quik95lt1's Avatar
got a dorman one from summit........im spinning my motor 8000+ and ive neva tossed or busted a belt.........except for that time by alternator siezed lol
Old 09-17-2010, 03:53 PM
MattSapp95_T/A's Avatar
I had one from advance auto too and never had a prob except it squeaked...
Old 09-17-2010, 05:18 PM
Rob94hawk's Avatar
good to know. Thanx
Old 09-17-2010, 06:29 PM
airfix's Avatar
I had to drill out the threaded holes and space it out roughly 1/4" on the **** pulley I bought. Sinnce then I deleted the power steering so, I'm just running the alternator now not other pullies.
Old 09-17-2010, 06:49 PM
Transamthunder's Avatar
That might be why I got mine for only 39 bucks also. I am doing a LT1 into my 85 Firebird, and I deleted the ac since there is to much work to get all that stuff in there. I hope the 2 washers for each bolt I put in is enough to get everything lined up and not shred any belts too.
Old 09-17-2010, 08:42 PM
airfix's Avatar
I used 3 washers on each hole. How many you need will depend on the thickness of your washers. Install it and use a straight edge to see if it lines up with your other pullies. Theres no need for trial and error, it's easy to get it right the first time.
Old 09-17-2010, 08:58 PM
Rob94hawk's Avatar
That must be a pretty short belt you're running! I'd like to do that but I'm sure it'll be a bitch turning with 275/40's on the front lol!
Old 09-17-2010, 09:10 PM
airfix's Avatar
I don't recall the length of the belt off the top of my head but it's pretty short. I'd imagine it would be pretty tough with 275's With skinnies it's easy. I havn't put my 275's on because I don't wanna put that much effort into turning the pos.
Old 09-17-2010, 11:34 PM
Rob94hawk's Avatar
Is this what you have?
http://www.summitracing.com/parts/RN...n/?prefilter=1
Old 09-18-2010, 07:43 AM
tscheu5452's Avatar
Originally Posted by Rob94hawk
That's the same POS I got from Advance. Plan on shimming it. From what I am hearing, the best piece is the GM 1LE AC delete pulley.
Old 09-18-2010, 10:51 AM
93TAJ.C.'s Avatar
get the dorman one, autozone sells it and it works good.
Old 09-19-2010, 10:41 PM
tricked94camaro's Avatar
I also got the one from summit. I also had to drill the threads out and add washers to the back of it to align with the rest of the pulleys. WTF? But I havent ran it yet. still in progress.
Old 09-20-2010, 12:21 AM
fex77k's Avatar
Originally Posted by tscheu5452
. . . the best piece is the GM 1LE AC delete pulley.
Yea my GM delete pulley hasn't ever been a problem.
Old 09-20-2010, 12:38 PM
camar0corey's Avatar
Had to shim the last one I installed, don't know where it came from though. Roommate got it used from a member on here.
Quick Reply: a/c delete pulley
