Cam Question
Old 11-26-2006, 05:53 PM
SSmokeDaGT's Avatar
Default Cam Question
Im about to buy a 224/224 112lsa cam and i want to know if i should install anything else while im working on it? I know i searched but couldnt find much.. Can i just throw in the cam and be done or should i purchase anything else. Cause im gonna buy the cam off a buddy..
Old 11-26-2006, 05:58 PM
SPRAYED 01's Avatar
Valve springs, pushrods, and tune, hopefully you have a free flowing exhaust and some intake goodies.
Old 11-26-2006, 06:38 PM
blkbird's Avatar
Timing chain wouldnt hurt........
Old 11-26-2006, 06:42 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Depending on higher milage motors it is a good idea to inspect, or replace the oil pump. I think if you have around 60k though, you should be fine. I would also suggest that you do the timing chain as well. The LS2 chain is peanuts over a full double roller setup. I would definitely do the chain, but if you plan on doing that then You will be able to get to your oil pump with ease.
Hardened pushrods are almost a must. Mechanical over rev will give your stock ones a pretzel shape if they give out!
Old 11-26-2006, 07:15 PM
slammedchevy's Avatar
i would put valve seals 2 if it is high miles
Old 11-27-2006, 04:08 PM
SSmokeDaGT's Avatar
Well I have a 02 so the ls6 intake is there and planning on getting a ported TB. My car only has 31k miles. So valve springs, pushrods will do.. How about timing chain? I currently have LT's
Old 11-27-2006, 05:49 PM
jcolews6's Avatar
I think you might want hardened push rods. What about an LS2 timing chain?
