Compressed Air + Cylinder = Pop! No Compression
Old 11-26-2006, 09:09 PM
FastJeep4X4's Avatar
Default Compressed Air + Cylinder = Pop! No Compression
My brother and I are doing a valve spring swap on an engine outside of the car, and used the air compressor method to hold the valves up. It worked well on all cylinders, but cylinder 1 we did last, we used less than 80PSI. All that I can think of is the valve was leaking and build up pressure since we had a long pause before doing that cylinder last. We heard a loud pop, and air leaks out nonstop into the engine somewhere. What could have happened so we have an idea how bad we are screwed. Thanks
Old 11-26-2006, 09:15 PM
Rhino79's Avatar
Ring maybe?
calongo_SS's Avatar
80 psi is no where near enough pressure to damage anything in the cylinder or combustion chamber. maybe there is a bent valve on that cylinder, see if you can tell if the air is coming out the intake, or going into the exhaust. if it's not going in one of those places it's got to be going past the rings.
Old 11-26-2006, 09:19 PM
Wait a sec, the front cover is off.... Is that the problem? We completely forgot it was off, since we need locktite for the bolts under it... Thanks for help guys
Old 11-26-2006, 09:20 PM
blkbird's Avatar
Are you sure the valve didnt just open up while compressing the spring? I had that happen to me a couple of times...
Old 11-26-2006, 09:36 PM
Ferocity02's Avatar
The front cover has nothing to do with it. The cylinder should hold compression no matter what. The crankcase doesn't hold pressure. In fact, if you put more than a few psi in the crankcase you'll blow out some of the gaskets.
Old 11-26-2006, 11:00 PM
You where right! we put the compressor on it and lowered it with TCD method and swapped spring and put it back and checked with air pressure to see and it had to have been open a little, no air escaped. Thanks blkbird
Old 11-26-2006, 11:38 PM
Oh4GTO's Avatar
^^^ I can feel the weight lifting off your shoulders.
Old 11-26-2006, 11:42 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
How'd you find that out Mike?
Old 11-27-2006, 12:05 AM
Ice Knight's Avatar
...LoL...
Old 11-27-2006, 12:32 AM
Ferocity02's Avatar
Quick Reply: Compressed Air + Cylinder = Pop! No Compression
