help GMPP intake
Old 11-27-2006, 04:46 PM
SELLSZ06's Avatar
Default help GMPP intake
I purchased a Edelbrock carb intake and elbow from intakeelbows.com. It did not fit under the hood of my 02 SS.Now I will try it with a GMPP intake, does anyone know for sure if that will fit under a SS hood? I emailed Aaron from intakeelbows.com and even he is not sure. any pics would be even better
Old 11-27-2006, 04:55 PM
SVC707's Avatar
the vic jr will not fit without cutting. the gmpp fit with just alil cutting of the cowl but i did not cut anything on my hood of the WS6
Old 11-27-2006, 04:59 PM
SVC707's Avatar
here you go just took these
but im not sure if afr heads make it sit higher, and also i think the poly mounts make it sit a tad different too.
Old 11-27-2006, 05:01 PM
SELLSZ06's Avatar
thanks for the pics! I wouldnt mind cutting that much, but I really dont want to touch the hood. Arent Ws6 hoods a little taller in that area?
anyone have pics of a SS hood, somebody has to have done it before on a SS
Old 11-27-2006, 06:49 PM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
i have it on my car and i've put this setup on other ss cars. the hood will close but it will rub a little on the under side of the hood.
Old 11-27-2006, 07:07 PM
SELLSZ06's Avatar
cool, with the GMPP? thanks. do u have any pics?
Old 11-27-2006, 07:12 PM
TT-TECH Veteran
Inspector12's Avatar
Well I know with a BMR and a GMPP and the elbow no cutting required. I milled my Victor Jr down and I am hopeing not to have to cut well see the poly mounts just keep the motor from moving witch also limits how much you have to cut etc...
Jeff
Old 11-27-2006, 07:27 PM
i'll see if i took pics of any of the cars.
Old 11-27-2006, 07:40 PM
SELLSZ06's Avatar
that would be great.
does anyone know exactly how much lower the GMPP is than a Edelbrock in inches?
Old 11-27-2006, 07:48 PM
ABeasst's Avatar
1/2" I believe
Old 11-27-2006, 10:13 PM
dont know if this will help but on top of the elbow you can kinda see where its rubbing a little bit . but it does clear the hood to close it.
Old 11-27-2006, 10:15 PM
oh its just rubs from the movement of the motor. on my car i had to cut the lower part of the hood anyways, cause i have spacers under the engine mounts to make more room for the turbos. hope this helps
Old 11-27-2006, 11:09 PM
SELLSZ06's Avatar
yes it does, thanks for taking time to do this.
I can either keep the elbow and NW tbody and return the Edelbrock, get the GMPP. or return the elbow, keep the Edelbrock and NW tbody and get this one : https://ls1tech.com/forums/nitrous-oxide/404043-nitrous-outlet-ls1-intake-system.html.
Has anyone seen this elbow?
Old 11-27-2006, 11:26 PM
ABeasst's Avatar
I have it on order.
Old 11-27-2006, 11:29 PM
SELLSZ06's Avatar
when do you get it? Dave said it was three weeks.
Old 11-27-2006, 11:37 PM
BigDB's Avatar
so with this type of intake and elbow combo I take it the air mettering has been converted to speed density since I dont see a MAF? If you dont mind what the benefit of going speed density and ditching the MAF? Sweet looking setups, hope you get the elbow situation straightened out.
Old 11-28-2006, 12:31 AM
SELLSZ06's Avatar
I also need to figure out the throtle cable, does it have to be shortened?
Old 11-28-2006, 04:15 PM
SELLSZ06's Avatar
so Iam keeping the Edelbrock and NW tbody and just ordered this http://www.nitrousoutlet.com/installs/install.asp?id=22
Old 11-28-2006, 07:01 PM
that will work
Old 11-28-2006, 09:49 PM
LS2Camaro's Avatar
Thats awesome, if that can allow the Vic Jr to Fit without hacking of the hood that sounds like a done deal to me. There is no price on that elbow in the link you provided SELLSZ06. What was the price on it??
Quick Reply: help GMPP intake
