2002 z valve springs
Old 11-28-2006, 07:20 AM
zrater's Avatar
Default 2002 z valve springs
how do you guys hold up the valves ,,when doing springs.
thanks again..........
Old 11-28-2006, 08:20 AM
blkbird's Avatar
Ive used the air compressor to hold up the valves, but there are other ways as well.
Old 11-28-2006, 09:35 AM
slt200mph's Avatar
You can turn the engine 90 degrees at a time to keep the valves from falling into the cylinders while you do the valve spring replacment. You can find the instructions on how to do it in the stickies. You can use compressed air also.
Old 11-28-2006, 03:48 PM
zrater's Avatar
anyone else,, thanks
Old 11-28-2006, 03:49 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I think that this is the external section....moving to Internal Engine.
