346 turbos garrett ???
Old 11-28-2006, 09:52 AM
camarokid94's Avatar
Default 346 turbos garrett ???
need 2 garrets for a 9:1 346 with ported heads and a turbo cam M6 will see mild track lookin for 10s but mostly street maybe 10psi and hopfully 650+ lots of TQ is needed and quick spool. thanks all going on a custom setou for a 02 ANN EDITON TA buddie sells garret but will use anyting if it will work better
Old 11-28-2006, 10:23 AM
LS1TECH Sponsor
DrTurbo's Avatar
A pair of TE44's will work great, if not a pair of TE32's.
Old 11-28-2006, 11:55 AM
who makes those what waht AR on both sides ?? thanks
Old 11-28-2006, 12:15 PM
LS1TECH Sponsor
DrTurbo's Avatar
They come with several A/R's to fit your application. All the units are Garrett based, and we carry some of them in stock.
Old 11-28-2006, 12:31 PM
how does picking a turbo chang when its twin im useing you website www.ForcedInductions.com
super help full by the way. i understand how to pick bassed on MAP but does it matter when theres two?
turboneticsinc like there T70 http://www.turboneticsinc.com/cm_t70.htm on 33 to 65 comsumption and 1.68 looks right cause it will use 10psi for sure maybe more in the future thanks
Old 11-28-2006, 12:34 PM
also how do you know how fast it will spool??
Old 11-28-2006, 01:10 PM
LS1TECH Sponsor
DrTurbo's Avatar
Remember you will need to divide the consumption in half when running a twin turbo setup. So 65/2 = 32.5. So using 32.5 lbs/min and plot it with a 1.68PR, and that will show you where on the map you are.
Old 11-28-2006, 03:07 PM
wow thanks
Old 11-28-2006, 05:22 PM
so all small turbos that will work for the MAP say it will work for like 2.0L-4.0L?? twins will work thought HUH using 16 on the low side and 31 high side normal 33-62 comsumption chart
http://www.turboneticsinc.com/cm_e50.htm
like this just use 2 im likin this one just cause he is talkin about uppin it to 14PSI so this would do for now at 10 and great at 14 right
Quick Reply: 346 turbos garrett ???
