afr heads and 918 springs
Old 11-28-2006, 11:32 AM
vader99's Avatar
Default afr heads and 918 springs
Will comp 918 springs work on afr 205 cc heads or are those heads machined to work with the double springs only?
Old 11-28-2006, 11:40 AM
Flow Wizard
Tony Mamo @ AFR's Avatar
Double springs equal more reliability (peace of mind), less breakage (we dont know of ANY of our standard 8017's or newer 8019's failing in the field), and more RPM potential from the higher seat and over the nose pressure.
WHY would you want to run 918's all those things considered?
Stick with the recipe....weve done all the R&D for you.
Tony M.
Old 11-28-2006, 11:59 AM
vader99's Avatar
Thanks Tony...
The only reason I was wondering was because I have a new set of 918's already and I found a used set of afr 205's that need new springs.
thanks for the quick reply.....
Old 11-28-2006, 05:17 PM
vettenuts's Avatar
918's new sell pretty quickly, I just sold a set a few months ago. They are in pretty high demand.
Good luck with your install!!!
