need help
Old 11-28-2006, 04:46 PM
bigpappasz28's Avatar
Default need help
how do you adjust the cable on the throttle body not the gas pedal one but the other due to i need to adjust due to spacer for the bbk 80mm throttle body?
Old 11-28-2006, 04:55 PM
one is the gas pedal and the other i think is the cruise control,it has a little white plastic on the side wich looks like the look to hole the teeth to adjust but how do you release the lock?
Old 11-28-2006, 08:59 PM
any one know how too
Old 11-28-2006, 09:01 PM
Tainted's Avatar
see if you cant have this moved to the general maintence and repairs
Old 11-28-2006, 09:02 PM
Long Beach's Avatar
Im dont think you can but not sure really. What year car do you have? You do know that the 1998-2000 tb are different than 2001-2002? But i would also like to know if it is possible to adjust this by that plastic clip.
Old 11-28-2006, 09:06 PM
6-Speed Terror's Avatar
the tb didnt come with spacers for the little metal part that holds the cables. i got two when i got my spacer and used one of those and have the other there available. i used a screwdriver to move the little bump on the plastic that slides in the hole is the car a4 or m6
Old 11-28-2006, 09:10 PM
no it did not come with spacers i got it on a trade for seven old pistons and rods from my old engine only came with the spacer at the back thats all no screws or gaskets,its an a4 and its a 1998 i think its for the cruise control and it looks like you can adjust it but dont know how to make it move,also how many gaskets come with it?
Old 11-28-2006, 09:37 PM
how do you remove locking clip on cruise control cable to adjust?????
Old 11-28-2006, 10:38 PM
ttttttttt
Old 11-28-2006, 11:03 PM
That's what she said...
TheBlurLS1's Avatar
I've never adjusted the cables, but that TB spacer is like putting on a tornado. Might as well take it off and eliminate the problem.
Old 11-28-2006, 11:06 PM
if i take the spacer off the throttle blade will not open it will hit the intake
Old 11-28-2006, 11:11 PM
TheBlurLS1's Avatar
What the hell are you running? 90mm TB on an LS1/6 intake? Post pics if you can.
Old 11-28-2006, 11:12 PM
nope its the 80mm bbk
Old 11-29-2006, 10:44 AM
unhook the cruise control and tie it with a zip tie thats also what i did on a truck that the spacer was to big for its been like that for yrs and problem
