Whistling Noise
Old 11-28-2006, 08:15 PM
01ghostwhitez's Avatar
Default Whistling Noise
My car has been making a whistling noise from 1500 rpm to 2000 rpm,sometimes. It only began after i installed the headers on the car and i have replaced the exhaust manifold gaskets twice so these are not leaking. Also i put ultra copper rtv silicone around all areas that my y slid in then band clamped them all. Has any one ever experienced this before and any ideas what it could be. Maybe the muffler going bad or something? I have mods in sig. Thanx
Old 11-29-2006, 02:18 PM
Any ideas
Old 11-29-2006, 02:33 PM
That's what she said...
TheBlurLS1's Avatar
Muffler bearings?
That's a strange problem. Usually an exhaust leak will be a puffing sound. You're going to have to localize it a bit more. Will it do it in neutral just revving? Which gaskets are your running?
Old 11-30-2006, 04:27 PM
Won't make the noise in neutral just revving. I'm using the oem gaskets on it. It only does it occasionally from 1200 - 2000 rpm but it is extremely annoying. Almost sounds like a horn or something. Its definately coming from the exhaust not the rear end. Usually happens just before it shifts.
Old 11-30-2006, 04:50 PM
Cop Car's Avatar
friend had that problem and it was one of the polution control lines that was off. i belive it was the AIR pump maybe? the thing you put a breather on when you do a lid. very possible you knocked it off while messing around down there.
Old 11-30-2006, 07:22 PM
Azrael's Avatar
Yeah check the intake/lid, see if the air connection was knocked off. They use cheap plastic connectors that can be brushed apart and allow air in. Usually whistling would be a filter or lid/intake issue. Make sure it is all snug and not letting in any air where it is not supposed too.
Old 11-30-2006, 07:23 PM
Blknight6989's Avatar
BLOW OFF VALVE????haha JK i swear!
Old 12-01-2006, 08:52 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Maybe somebody installed a Procharger on your car without telling you.
Old 12-01-2006, 11:05 AM
Yea that would be nice! Merry Christmas! Anyway's, i checked the intake and the AIR hookups and everything looked good. Car kinda made this noise a little before but it is much louder since the header install. Hence why i think it might be the muffler. Any other ideas guy's?
Old 12-01-2006, 11:12 AM
bayer-z28's Avatar
Tighten your header collector clamps. I'll put $$$ on it that's your problem. I did my transmission and I had to yank the Y-pipe, so after I re-installed it, I tightened the clamps, and she's whistling now... It's done it before, I just haven't gotten a chance to mess with it.. It sounds almost like a squeaky belt... Anyoying, but get on it, or crank the radio, and you won't notice it anymore.
EXH leak...
Old 12-01-2006, 11:26 AM
Nope not really the sound i hear. It almost sounds like a fog horn or something. But i will check all of the clamps and tighten them again just to be sure.
Old 12-06-2006, 09:33 PM
I was told by a local muffler shop that the muffler itself is causing the noise. He told me he has had multiple flowmaster exhaust come in making noise and it was the muffler. I want to replace the muffler and i'm considering a hooker aerochamber! Is this a good choice for my set up? What do you guys recommend.
Old 12-06-2006, 11:27 PM
sdbrown84's Avatar
Hooker is fine. If you want great flow I have had great luck with the Magnaflow, never a "whistle" from mine.
Old 12-06-2006, 11:35 PM
Azrael's Avatar
Magnaflow...
Old 12-07-2006, 06:26 PM
SS1875's Avatar
Magnaflow or Hooker would be a good choice both flow nicely , the Magnaflow looks better though.
Quick Reply: Whistling Noise
