12 Second Club - wanting to hit 12s
onebad400
11-29-2006, 08:32 AM
i just bought a 2000 trans am ls1 m6 (not a ws6,but does have ram air hood if that makes a difference.) and i was wondering what it would take to get the car to run 12.80's. i was thinking headers full exhaust and slp cold air
SCP_Racing
11-30-2006, 07:47 AM
with the m6 u might want to look into some sticky tires and be careful not to throw ur gears out the back
austin21
11-30-2006, 09:06 AM
some nitto's would be useful
onebad400
11-30-2006, 10:47 AM
ok obviously i am new to the whole ls1 thing but what is so weak about the rearends? and what can do to change this?
HOTRODKEV
11-30-2006, 10:55 AM
Spend some serious money and get you a 12 bolt rear end.
SuperSport4life
11-30-2006, 11:33 PM
Well the 10 bolts have a reputation for being some of the weakest factory rear ends out of detriot. Its about 7.5 inches wide so its very small and in the rear end world wider is better. They also have to handle 300 hp and 300 lbs of torque straight from the factory which is alot for a 7.5 inch wide rear to handle. Best idea is to get a 12 bolt or 9". I'll be doing this shortly because I know my 10 bolt will probably break if I try to track it again after 35 + abusive track passes!
onebad400
12-01-2006, 08:57 AM
but if i am only going to run street tires and the only mods i have planned and headers ory, slp cold air, and a ls6 intake do i really need to spend the 2500 on a 12 bolt or a 9 in? i figured with street tire it would spin before it snaped. and even if i take it to the track i will not be lauching at more than 2000 ever i have a friend with a blazer with a ten bolt and a heavily moded lt1 in it and he has drop his from 5000 rpm a number of times. i am just trying to see if the money is neccessary to spend.
LITE SPD
12-01-2006, 09:39 PM
I'd just go with a good summer tire if high 12s are your goal.
onebad400
12-02-2006, 02:41 PM
but the question at hand is will a good summer tire break loose before it will snap the rear.
landstuhltaylor
12-02-2006, 02:49 PM
it is not unheard of
2002LS1Z
12-03-2006, 04:39 PM
If you are on a budget: Lid, cutout, sticky tires, minor weight reduction and excellent driving may get you there, if your car is a strong runner.
LSGunZ28
12-03-2006, 05:39 PM
If you are running street tires you have no problem and probably wont break your rear. But good luck hitting 12s with street tires. You have more of a chance using street drag such as Nitto 555rs stock hitting 12s, then having full intake and exhuast, using street tires.
Tudds
12-04-2006, 11:05 AM
If you are a crappy driver mods aren't going to help you
slowpoke96z28
12-05-2006, 03:55 AM
its going to take some mods to run a 12.80 if you dont plan on getting a good 60' out of the car. it takes a lot more power to go fast on the big end than it does on the little end.
onebad400
12-05-2006, 10:21 AM
so what you guys are saying is that i should invest in some nitto's. so if i do get a set would 1500 rpm lauch snap the twig rearend?
FLASH1970
12-06-2006, 12:42 PM
i got M/T et street drag radials (they hook up more than a $2 whore in Vegas), SLP intake, smooth tube, and a NX 150 shot on a 2002 WS6 M6. my rear end hasn't broke. yet. the stock clutch is pretty weak and i smell it when the 150 shot hits. so, what i'm getting at is the clutch in my car slips before the rear ends breaks. granted, a new rear end is on my 'to get list' but if mine holds up with my mods, you shouldn't be worried throwing drag radials and a full exhaust at it.
jitsumania
12-06-2006, 05:53 PM
I just put a set of Nitto Dr's on mine. Was runnin Kuhmo Z rated Street tires but I just can't seem to put those brand new (kuhmos) tires back on since I put those Nitto's on, LOL. I dont believe that you will crap out your rear with a few good Launches over 1500 RPM's, but I would not overdo it, which means hot lappin at high RPM launches at track is a definate no no. Should not tempt fate. Just ran a 12.72 a couple of weeks ago with the mods in sig and a 1600 launch with stock rear end and gears.
http://s78.photobucket.com/albums/j90/jitsumania/?action=view¤t=Sleepers1272run_0001.flv
If you want balls to the wall then change out your rear end so you will have no worries!
ZTwentyAteU
12-06-2006, 09:04 PM
I ran 12.80s with my 01 Z on street tires.Cheap ones....Hankook Ventus 275/40/17s. I got best of 1.89 60 ft on them.
Mods were: SLP Lid, FRA, gutted cats, o2 sims, Loudmouth II, Eibach Sportlines, Adj PHB
NO TUNE! You can do it!
