Need tranny help
Old 11-29-2006, 07:55 PM
SierraSport's Avatar
Default Need tranny help
I put my new tranny in and it wouldnt go into second but would go into 3 and O/D. We went back in and check a couple of things( the 1-2 shift springs and ball, the servo on the side of the tranny). We put it back together and now it will shift great though all the gears but when Im driving it down the road it wont downshift to 2nd, it wont even downshidt into 2nd manually.. It will Manually downshift into every other gear.. I cant figure it out.
Someone help PLEASE !! I need my truck back up now that it is getting colder and all I have is my truck and bike ..
Old 11-29-2006, 07:59 PM
The parts that where put in the tranny..
TransGo ShiFt Kit
Kevlar Clutches
Billet Shift Servos
Hardened Sun Shell/Planitary(sp)
Yank TT3000
I cant think of everything, but it is built ..
Old 11-29-2006, 08:14 PM
FLT
FLT's Avatar
Are you getting any codes? It is possible that you have a bad 3-2 solenoid or unpluged one. Also there is a spring that likes to break behind the 3-2 shift valve. This might not be the problem but something to look at. Vince
Old 11-29-2006, 08:19 PM
no Codes
he is getting me a new 3-2 solenoid
we checked the springs with the check ball at the back of the tranny inside the pan??
Old 11-29-2006, 08:22 PM
FLT
FLT's Avatar
Please retype your reply.
Old 11-29-2006, 08:37 PM
Sorry, getting kind of pissed at my tranny builder..
Fixed
Old 11-29-2006, 08:55 PM
FLT
FLT's Avatar
I believe what you checked was the 1-2 shift valve. The one I'm making reference to is in the front of the valve body closest to the TC. If you look at this picture it is the one with the white connector on the right. This is the 3-2 solenoid. I would be looking in this area. Behind that solenoid is a valve with a spring that likes to break. This could be your problem. Who is doing the work on this trans?
Old 11-29-2006, 09:08 PM
Corey Manchaca
He is just a guy that builds my trannies here in Austin, I have never had a problem before with his work ..
Old 11-29-2006, 09:13 PM
LS1Tech Sponsor
performabuilt's Avatar
Well as vince was saying the 3-2 o the spring in the valve bore are the most likley things.
As for the builder he may be very good anyone can have a problem and everyone does eventually its how they handle it that makes or breaks them
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 11-29-2006, 09:41 PM
Gilbert@Ace Racing's Avatar
As you know automatics are quite complicated. Diagnosing this type of problem on the web, in a forum is even more complicated.
As previously stated there is a control issue... if it is upshifting fine then it can be assumed that the rotating assy. is just fine. The most logical place to start is the 3-2 solenoid and related valve train. This type of failure is not easily resolved, your builder should have a scanning tool, it should have the ability to drive or operate the solenoids with the key on, engine off. Ask him to check the solenoid in this manner before replacing it as there can be a termination issue outside the trans as well as at the solenoid.
Let us know what took care of it.
Old 11-30-2006, 01:29 AM
LS1Tech Sponsor
And yes diagnosing online difficult thats why we are here lol
__________________
Call 888-744-6542
Old 11-30-2006, 01:43 PM
Thanks for the help, I will bring this info to him and see what he is going to do ..
Old 11-30-2006, 03:20 PM
LS1Tech Sponsor
Good luck and keep us posted
__________________
Call 888-744-6542
