MS3 but what lsa?
Old 11-29-2006, 11:51 PM
smokey1226's Avatar
Default MS3 but what lsa?
From TSP i have a choice of 110-116 If i remeber correctly? If im looking for a good chop im looking for a 112ish right? Or what do you guys reccomend for the ms3? This is going into a 01 z06
Old 11-30-2006, 12:42 AM
prplhaz's Avatar
In general increasing the LSA will decrease overlap and overlap is the "chop" producer.........so the 112 will be choppier than the 114. That being said TSP has in the past has had some advance ground into their cams too.
Old 11-30-2006, 11:50 AM
rickyracer25's Avatar
112 is the tightest with out PTV issues and I would call them to make sure they can't talk you into a Ms4... LOL I love my MS4,
Old 12-01-2006, 09:49 AM
erikthegoalie's Avatar
I went with a 113...I heard it is still choppy as hell...I just wanted a bit more PTV clearance!
Old 12-01-2006, 10:24 AM
1fastz28nx's Avatar
You won't be dissappointed with your choice, I promise! It's a ground pounder!
Old 12-01-2006, 10:27 AM
KingSS's Avatar
Get it on 113 or a 112. I have mine on a 113 and it cams harder then most other cammed cars ive heard.
Old 12-01-2006, 11:40 AM
smokey1226's Avatar
Fill in me on the slight differences between the MS3 and MS4....my main goal is to NOT have to do anything with the stock ls6 heads on a 01 z06. I will be going with TSP's package with the hardened rods, springs ect. So will the ms4 be good with the stock heads on the z06? I think ill go with 113lsa only because i want a good chop but i will use the car for some daily driven. So i dont want it to obnoxious
Old 12-01-2006, 11:53 AM
KingSS's Avatar
Yes the ms4 will fit as long as you keep the stock valve size in the heads. If you get larger valves you will definately have to flycut in order to get the MS4 to fit.
Old 12-04-2006, 11:42 AM
smokey1226's Avatar
i dont have to do that with the ms3 though right?
Old 12-04-2006, 12:55 PM
2000TransAmWS6's Avatar
i don't believe that a MS3 would fit on bigger valves either.
it seems to me that even if the MS3 (or 4) were on a 114 or 115 it would still have a pretty choppy idle... the MS cams have a bunch of overlap.
Quick Reply: MS3 but what lsa?
