ques about victor jr. intake clearance
Old 11-30-2006, 07:53 AM
D'scamaro's Avatar
Default ques about victor jr. intake clearance
i have a ss hood and was wondering if it would fit under my hood, im going to go with the efi and not the carb on my 408.. with 4400 stall and th-350... what all do i need besides the rails and elbow?? and will stock injectors work, i have the #28 ones... and i guess you have to custom fab up something to go from the lid, maf and to the t/b right??
and how much taller is the elbow for it than an ls6 intake, thanks
i just dont want to buy it and it not fit under my hood... and am not going to lower my motor.... thanks in advance, dwayne
Old 12-09-2006, 08:52 PM
FRUSTRATED T/A's Avatar
also interested and how much can the motor be lowered? and how by the motor mounts?
Old 12-09-2006, 09:04 PM
PRAY HRD's Avatar
don't know personally, but i just bought an elbow from a fellow member because it didn't fit under his ws6 hood with the vic jr.
Old 12-09-2006, 09:18 PM
you talking about the efi or curbed. Any one have a good picture of one installed efi. As im thinking of different intake options here. And that thing does look bad a$$. I wounder how it flow n/a 402 afr heads. i thought they had one where the tb was on front not top. I saw a picture of one or my mind started to wounder again.
Old 12-15-2006, 05:56 PM
D'scamaro's Avatar
the elbow makes the t/b in the front.. and i think it can come with a 105mm t/b also!!!!! i was wondering also for my 408, thanks, dwayne
Old 02-18-2007, 01:19 AM
D'scamaro's Avatar
any pics??
Old 02-18-2007, 01:29 AM
dixonk's Avatar
I have a buddy here that has the elbow on his formula and he just had to knotch the back side of the hood a bit nothing too visible.
Old 02-18-2007, 02:34 AM
DanZ28's Avatar
You might have to (most likely) notch the rear cowl area next to your window.
Old 02-18-2007, 03:48 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Well, I can tell you right now that those 28#'ers are not going to be a match for a 408. I would look into some 36# SVO's, and at a minimum 30# SVO's that are rated around 36# on the LS1.
Old 02-18-2007, 01:54 PM
Bird-Of-Prey's Avatar
Here's a pic of my Vic Jr. with Aarons elbow on a '99 T/A with a standard hood. You can see at the top of the pic that it does just barely rub the hood.
Old 02-19-2007, 02:53 AM
dixonk's Avatar
Ya thats what I was talking about where my friend knotched the hood so it doesn't rub just lightly go over it with a dremel.
Old 02-21-2007, 03:32 AM
D'scamaro's Avatar
thanks for the pics guys!
Quick Reply: ques about victor jr. intake clearance
