238/242 .600/.610 114+4 what do you think.
Old 11-30-2006, 09:21 AM
SPRAYED 01's Avatar
Default 238/242 .600/.610 114+2 what do you think.
This is the cam that my local speed shop ordered for me. They said it would work very well with tmy setup and on the spray. What do you cam guys think? Ill me upgrading to 42pound injectors and swaping the 411 gear for a 370. All other mods in sig.
Old 11-30-2006, 09:23 AM
sparky t/a's Avatar
looks like it'll boogie on or off the spray
Old 11-30-2006, 09:50 AM
Ragtop 99's Avatar
The cam has a very late IVC and very early EVO. You'll make tons of power very high in the power range. Hope your planning to shift at 7000 to get the most out of this. Good thing you have a 4000 stall.
Old 11-30-2006, 10:19 AM
SPRAYED 01's Avatar
How much will it hurt the car to shift at 6800 instead of 7k. My tuner also said to get the most out of the cam we would have to shift at 7k.
Old 11-30-2006, 12:55 PM
slow trap's Avatar
that is a huge cam for a 346.very similar to the x3 but 4 * bigger on the intake side.is your pistons flycut any ?
Old 11-30-2006, 02:05 PM
Ragtop 99's Avatar
Probably not too much. Being an A4, you'll wind out 1st and 2nd and won't come close to red line in 3rd running NA unless you have a very loose converter. Since you are spraying, hopefully your converter is fairly tight.
Old 11-30-2006, 04:25 PM
SPRAYED 01's Avatar
Correction its a 114+2, im running a yank SS 4000.
Old 11-30-2006, 09:15 PM
SPRAYED 01's Avatar
ttttt
