is this cam a good choice
I am putting a 2000 ls1 motor out of a c5 in my truck and thought this might be a good cam since I will want my power lower with the weight of the truck.
HYDRAULIC ROLLER, Good idle, excellent low end torque and mid-range horsepower.1800-4800
212°
221°
.510"
.510"
.300"
.300"
116° Sep
112° Int C/L
-06°BTC 38°ABC /
50.5°BBC -9.5°ATC
212°
221°
.510"
.510"
.300"
.300"
116° Sep
112° Int C/L
-06°BTC 38°ABC /
50.5°BBC -9.5°ATC
Re: is this cam a good choice
Personally, I wouldnt use that cam. There is too big of a split between the intake and exhaust durations. Also the LSA is too wide. I'd look into the comp 212/218 114 LSA cam. It also has lift at about .525". See the post in the truck section under my name about a 216/216 XE comp cam in a 5.3L truck. I like to use single pattern cams in LS1, which have the same intake and exhast durations.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Raughammer:
<strong> But why would you put so much timing on the exhaust?
John </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thats why I asked the question? What would be the benefits? What would be a good choice of cam for what I doing?
