A quick and easy question for you LT1 guys
Old 12-01-2006, 10:15 AM
The SSheriff's Avatar
Default A quick and easy question for you LT1 guys
I have heard time and time again that people's "Opti's" are failing. What exactly is an "Opti"? I just know they were LTx problems only, and apparently I am glad that my car doesn't have it.
Old 12-01-2006, 10:29 AM
SlowGreenTA's Avatar
Optispark. Its our spark distributor. The main problem is if it gets wet, it can fail, and placed behind the water pump, it sometimes gets wet.
And you are correct, LSx engines have individual coil packs iirc?
-Josh
Old 12-01-2006, 10:46 AM
ws6chicken's Avatar
The actual opti spark is 2 mechanisms in one. There is the sensor part which consists of a disc with slits in it that is attached to the cam and measures the position of the cam, the other part is the distributor that sits in front of the opti sensor.
Old 12-01-2006, 11:23 AM
LT1MAN's Avatar
opti's get oil on them alot too and fail.
Old 12-07-2006, 09:02 PM
Yes, we are coil on plug ignition in the LS1's. Thanks for clearing that Opti mystery up with me.
Old 12-07-2006, 09:06 PM
Cammed95Z28's Avatar
Correct, its a camshaft position sensor and a distributor in one. Like they said it likes to get oil in it and the BRILLIANT GM engineers put it underneath a waterpump that likes to fail and weep through the weep hole onto it But alas, MSD has saved us(for those who can afford it). I went through 5 Opti's before having no problems with my MSD.
Old 12-07-2006, 09:20 PM
MEAN LT1's Avatar
The optical distributor is actually a good design, its just in the wrong spot. I had 165,000 miles on mine before I put another rotor on it.
Old 12-07-2006, 09:26 PM
the_merv's Avatar
Yea, I have to replace my Water Pump, and I think that is what causes my sputtering at 5500+rpms. I am going to make a little shield for it out of aluminum flashing.
Old 12-08-2006, 07:45 AM
How much are Opti's, just to be curious??
Old 12-08-2006, 07:55 AM
Internet Mechanic
BlackScreaminMachine's Avatar
A opti is a fun day
Old 12-08-2006, 08:01 AM
Internet Mechanic
Depends, if its a GM Opti it could be 500+ or if you know where to get it ive gotten them for high 200's. There are aftermarket ones from Summit to MSD,
Old 12-08-2006, 08:13 AM
97ssmokem's Avatar
Originally Posted by BlackScreaminMachine
A opti is a fun day
I can change mine in the 94 Z28 in about 35 minutes.
Old 12-08-2006, 10:59 AM
Internet Mechanic
Ive done one with in an hour, with out help or lift, jackstands and hand tools.
I was speaking to this post initial question
Old 12-08-2006, 11:07 AM
Sweetred95ta's Avatar
The rotor on the stock opti isn't anything to brag about as well. They have a tendency to 'pop' apart.
Old 12-08-2006, 11:59 AM
the_merv's Avatar
A opti is a fun day
Hour and a half, and that's from running to starting again.
Quick Reply: A quick and easy question for you LT1 guys
