Removing front turn signals bulbs
ok, can't seem to figure out how to remove the turn signal bulbs (not DRL/Parking bulb that was easy), I'm talkin about the bulb's that are closest to the grill. Pic's would be a real help!!
trying to t/s bad turn signals I Think it's the bulb in drivers front.
Thanks!
Thanks!
I do it from the top. Remove the 1 bolt that holds the headlamp in, then slid it out and disconnect the low & high beam bulbs. With it out of the way you can get right to the turn signal bulb.
You can also do it from the bottom, but I've never done it that way. It involves laying on ground, removing the two bolts on that little flap, and reaching way up inside it.
Originally Posted by JEB Garner
Guys, Do you not know that there are little doors under the front fenders that was put ther so that you can get to the bulbs and change them?
I do thats how i changed mine. Way easy
Every time I drive in the rain, mine burn out! It is so annoying! I thought maybe it was where the clear front part connected to the housing that water was getting in so I sealed them up good but it's still happening! Water has to somehow be getting in where the bulbs insert into the housings
yeah do it from the top b/c it is so much easyer. As for the blubs burrning up when in the rain. Dont seal them up compleatly. They just pop. I found drilling vent holes in them help out alot. I use a small drill bit and druill like 5-7 holes on the bottem of each. I havent run into burning or melting of the plasic yet.
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
