Drag Racing Tech
how much is 60ft going to drop with 300bl weight reduction?
Old 12-03-2006, 06:45 AM
Houston999's Avatar
Default how much is 60ft going to drop with 300bl weight reduction?
how much is 60ft going to drop with 300bl weight reduction? my current 60ft is 1.53 weight is 3300 going to drop weight to 3050bl with brakes aliminum drive shaft ,kirkey seat, dry cell battery , no power steering,fiber glass hood,ewp,... the car is 347ci and th400 12 bolt moser
I ran 10.99@123.2 1.53 60ft last time .what is the effects of dropping 250bl-300bl on the et mph 60ft numbers?
thanx in advance
Old 12-03-2006, 08:33 AM
JPJBC's Avatar
They say 100lbs= .1 et and 1mph. As far as the 60ft goes, Im not sure. I would like to know this also.
Old 12-03-2006, 09:51 AM
TS6
TS6's Avatar
Pound=lb, not bl.
Old 12-03-2006, 10:13 AM
tektrans's Avatar
.3 in the 1/4 all things being equal. 60' is more of a power and suspension thing if you ask me. Theoretically (TS6 did I spell that right ) 300 less bl's (hehe) should take less power to move so your 60 should drop but I would guess not by much. Also going to depend on where that weight is coming off of.
They say .2 drop in the 60' is worth .3 up top but I don't see that happening with your set up as it sits, or mine for that matter.
Houston999's Avatar
Originally Posted by TS6
Pound=lb, not bl.
Old 12-03-2006, 12:12 PM
TS6
TS6's Avatar
Sorry, it bugs me. I'm weird like that.....
Old 12-03-2006, 12:17 PM
GIZMO's Avatar
You will probably see a .02-3 gain in sixty. Change that TH-400 for a TH-350 with a low gear set and you will see a big gain.
Daren
Old 12-03-2006, 12:52 PM
Houston999's Avatar
Daren
is that true?!
Old 12-03-2006, 08:44 PM
mike c.'s Avatar
in my case the more weight i remove off the nose the better my car will 60 foot. 300lbs is alot of weight to not carry around anymore. goodluck to ya.
Old 12-03-2006, 10:11 PM
Houston999's Avatar
what if i swapped th400 from (2.48,1.48,1) fears to (2.75,1.57,1) any changes in 60ft,et or mph?
Old 12-04-2006, 02:18 AM
dug
dug's Avatar
I calculated 1.47s from a physics formula. It assumes a constant uniform acceleration without any rollout accounted for. Its obviously a rough approximation.
Old 12-04-2006, 08:05 AM
GIZMO's Avatar
Originally Posted by Houston999
is that true?!
If you are planning to run N/A, any weight that you can get out of the rotating assembly is a big plus. I have a friend that blew-up his locally built TH-350. I lowned him one of my "Stocker" TH-350's (Low gear-set and other tricks) and his car picked up a tenth. That's TH-350 for TH-350! I have a Th-200 here that is a little over a tenth faster than my best TH-350. With a good tune you could probably drop your 10.9 to a 10.7 if you buy a good transmision and converter. Expect to pay as much as $3,500.00 for a good TH-350 set-up.
Good Luck,
Daren
Old 12-04-2006, 08:20 AM
Shon Herron's Avatar
Lets just say that removing the weight will not slow you down.
Old 12-05-2006, 01:05 PM
T6Rocket's Avatar
Good Luck,
Daren
Dropping 300 lbs should put him in the 10.7's without a tune or different transmission. In other words, without spending another dime, other than the $$ spent on the lightweight stuff.
60' should improve nicely. With less weight, it should move better from a stop.
Al
Old 12-05-2006, 07:34 PM
TNTaddict's Avatar
what is the wt diffs. between TH400 and TH350???
Old 12-05-2006, 11:04 PM
Houston999's Avatar
i think the th350 is 10lb lighter but the th400 is tougher
Old 12-06-2006, 08:52 AM
Ls1LikeNoOther's Avatar
Put the 2.75 gears in the th400 match it with a good custom built converter for your application and your 60's will drop...
Old 12-06-2006, 11:33 AM
Houston999's Avatar
the 10.99 run vid
http://video.google.com/videoplay?do...80384287&hl=en
what do y'all think?
Old 12-06-2006, 03:10 PM
GIZMO's Avatar
Originally Posted by T6Rocket
Dropping 300 lbs should put him in the 10.7's without a tune or different transmission. Al
And a TH-350 will be faster than the TH400 unless you pay mega $$$ for the TH-400. A Th-400 isn't the best modification you can make if you want to go fast N/A.
Daren
