cleaning my intake
Old 12-03-2006, 10:20 AM
99SeanWS6's Avatar
Default cleaning my intake
i have a ls6 intake that i bought from another forum. its kinda dirty as though its been sitting in a garage for quite some time. is there a safe way of cleaning it, inside and out, before installing it??
Old 12-03-2006, 05:05 PM
Grimes's Avatar
just spray it down with some simple green, let it soak, and then rinse off
Old 12-03-2006, 05:08 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
SOAP AND WATER..SIMPLE GREEN....VINEGAR AND WATER...ETC..ETC..ETC....where have u been....
Old 12-03-2006, 05:12 PM
Grimes's Avatar
haha, vinegar....may i also suggest painting it a cool color before you install? It may be a bitch to mask off, but it will give a nicer custom look if done right.
Old 12-03-2006, 08:14 PM
99SeanWS6's Avatar
thanks guys. yeah gimes, i was thinking of doing it pewter to match the car since i have two new side mirrors that i need to get painted
Old 12-03-2006, 10:02 PM
SweeTbone's Avatar
Masking it off was the easy part. The bitch was all the sanding, especially down in the crevices. Quite a few hours in sanding but it's all worth it.
Old 12-03-2006, 10:30 PM
Luna's Avatar
Simple green will work most of the time, but my LS6 had like baked on oil caked all over it and that **** would NOT come off and simple green just turned it all red. I more or less had to sand it all off, even a pressure washer wouldn't take care of it.
Good luck, painted intakes always look great if you put the time into prepping it right.
Old 12-03-2006, 10:59 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I don't think that you can clean it if you didnt buy it off www.LS1tech.com.
LOL!
Actually carb cleaner and a rag will do wonders. Make sure that you pull the rubber gaskets off though if you chose to do that option. Not sure how that affects the integrity of the rubber material of the gaskets mixing it with something like carb cleaner.
Old 12-03-2006, 11:26 PM
evrae205's Avatar
I used carb and choke cleaner and then a high air pressure blower from our shop to spray out the gunk and cleaner. let it dry REAL good then put it on.
Old 12-03-2006, 11:33 PM
That's what she said...
TheBlurLS1's Avatar
I've cleaned up some serious disasters with Gunk brand Foamy Engine Brite. My DD looked like someone took 10 gallons of mud/water dumped under the hood.
1 Pass with long bristled wheel brush + foamy, then 1 pass with simple green and clean brush, then thorough rinse/air dry = blang blang.
Here's what the stuff looks like....
Old 12-04-2006, 12:06 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Gunk works great too.
