Analog speedo, oops
Analog speedo, oops
I bought all autometer gauges for my swap but bought an analog speedo. The swap is a 6.0l 4l80e with np241c transfer case. Is there any way to run a speedo cable from the transfer case to the speedo? Or should I just sell it and try again?
I can't remember the name but you can do a search on it.
You would have to switch out the tail of the trans or buy the box to convert a signal to the mechanial speedo. The box is about $300 and from what I have read is not that accurate. I looked into this to be able to retain the stock dash in my trans am. I found it cheaper to buy the electronic autometer speedometer.
This is the link to a company that manufactures a box to convert the electronic signal to a manual speedometer.
http://www.abbott-tach.com/cablex.htm
