Ryanmgaspard
12-03-2006, 02:13 PM
Car stumbles when heavy accelerating until you let off the gas. Sometimes will just die going down the road. Idle is good for 5 secs at a time then stumbles 1 sec then back. I have no engine mods. I did the TB bump stop mod and TB bypass mod.
Did a drill mod, flushed clutch master cylinder, replaced plugs and wires, replaced fuel filter, electronic cleaned MAF and fittings, tightened clamps on induction, tried to reset CEL, didn't work. Also have a new accessory belt. My new plugs and wires helped out with the bad idle and stumbling. I'm pullin codes:
P0102 MAF or VAF Circuit Low Input
P0103 MAF or VAF Circuit High Input
P0704 Clutch Switch Input / Circuit Malfunction
I got a new switch for clutch also and I'm still getting these codes.
