4l60e ????????
4l60e ????????
anyway to adjust(set) the tv cable in the 4l60e(94 model)? or does the computer control it all? i know it has the cable going to the throttle body like earlier models.
yes i know, i just didnt know if adjusting the t.v. cable would have any effect. the car will not shift out of 1st under w.o.t. and doesnt like to shift while giving it much gas at all.
Did you keep the original tranny from the 93? If so, then it's a 700R4/4L60, and you have a TV cable, which yes you can adjust. It might be TOO tight and I think that'll keep it from shifting, or is it too loose?
