Check Gauges light flashing
I noticed tonight that if im at WOT my check gauges light will strobe. Its only above 3000 rpm or so as well. I tried in 5th and 6th but it didnt light up so i went to 4th and it strobed. Any ideas, N2O wasnt activated so im sure its not amp draw from the kit. Thanks
ill look, didnt see anything out of the ordinary. My temp gauge has always read low just a lil over 160. Where is the temp sensor for the gauge located at?
Mine came on when my serp belt flew apart on the highway, most likely because my alt was no longer spinning, causing the volt meter to drop pretty quick. Maybe at higher rpms your alt is cutting out?
Originally Posted by autotrix
Maybe it was your tach!
