Magnaflow Cats
1 Post
Magnaflow Cats
http://www.car-sound.com/02product/u...al/549spun.asp
Looking at this series cats for my 01 SS, will probably be running stock Y and will be running stock manifolds, but changing my borla exhaust to powersticks.
How will these cats do on this setup? Anyone else running these cats? What size should I get seeing as i'm running stock y-pipe and manifolds?
Thanks,
Caleb
Thanks,
Caleb
Those look to be standard ceramic cats, but a little smaller in overall size than the standard Magnaflow cats. They should flow nicely.
However it probably is not worth doing the swap if you are going to be running the stock y and manifolds. You're probably not going to see enough gain for it to be worth it. I would wait till you do the rest of the exhaust (headers and duals or headers and high flow y) before you replace the cats in a stock system.
I see...in that case yes those cats would work well indeed. They will be smaller and lower in profile than the typical magnaflow cats...which is always good, plus they will flow great. You want the 2.5" ones to connect up to the stock piping.
1 Post
I'm really trying to figure out something with the best sound yet isn't busting expensive. I've changed my mind and am planning on ordering a universal x-pipe from summit racing and then having the exhaust shop fab up the piping so that I can run duals with 2 Powerstick mufflers and then dump it off after those before the axle if possible. The stock manifolds are 2.5" piping into the y-pipe correct? So should I order the 2.5" x-pipe or should I get the 3" x-pipe and also 3" powersticks? How much of a sound difference and flow difference would having the 2.5 have instead of getting the 3"?
In opinion how much would an exhaust shop cost to fab up the piping if I have the x-pipe kit, mufflers, and catalytic converters??
Also, does anyone know about how much the spun catalytic converters run?
MASS seller approved
Those are the metallic spun cats. They have just been out for a couple months now. They are the highest flowing Magnaflow cat available. They flow ~570cfm where as the ceramic cats from Magnaflow flow in the low 400s. I'm running these exact cats in my personal car.
We sell them for $179 for a pair. They are available on our website.
Originally Posted by ckingcmaro
What do you guys think an exhaust shop would charge fabrication and installation to do this?
1 Post
This worries me a little bit about doing this, so I want you guys opinion on it.
Want to run the 549 spun catalytic converter series into an x-pipe and then into 2 powerstick mufflers dumped before the axle.
This is what worries me a little though, could I buy this universal x-pipe kit and use these clamps and this setup work and flow well? Also would those clamps hold all this together?
Or would it be better & cheaper to just have an exhaust shop fab up an x-pipe and just supply them with the cats and mufflers?
If I were you I would take the parts to your exhaust shop and just have them do the labor. Just make sure the xpipe you get is a volumetric xpipe, which keeps up velocity, with larger than standard diameter. I've seen some kits that were not volumetric and they definately don't flow as nicely. If you have a picture of the xpipe you can tell if it's volumetric or not. As far as assembly let your exhaust shop handle that, if the hardware is good quality no reason not to use it. It probably will cost more than a few hundred dollars complete.
IF you just have to replace the cat and your car has less than 80k miles the dealer will do it for free. Emission equipment is covered for 8 years or 80k miles by federal law. Just an FYI. I used the magna flows with edelbrocks on a friends SS and they were a really nice piece.
Josh
Josh
Would it be cheaper to let the exhaust shop fab up the whole x-pipe or buy a universal kit and give them that?
