tranny rebuild kits
Old 12-05-2006, 11:39 AM
chameleongreen97ta's Avatar
Default tranny rebuild kits
where can i find a good rebuild kit for my 4l60e i found one but not sure if it has everything included in it
this is the one i found already
"Front pump"
Seal retainer
Late design seal
10-vane rotor w/vanes & slide assembly
Trans-Go steel rings & priming spring (under 5,500 rpm)
New replacement stator support
"Clutches, Steels And Pressure Plates"
4 Borg-Warner reverse/input clutches .068
4 Reverse/input "low drag" Turbulator steels .078
1 .078 spacer plate with reverse wave (eliminates the belleville spring)
5 Borg-Warner forward clutches .070
5 Forward steels .090
2 Borg-Warner overrun clutches .078
8 Borg-Warner Hi-Energy 3-4 clutches .080
3 3-4 steels Kolene .060
5 3-4 Steels Kolene .076
2 3-4 pressure plates .128
5 Borg-Warner low/reverse clutches .087
5 Low/reverse "low drag" Turbulator steels .068
1 3-4 apply ring 5-tabs
1 .062" 3-4 snap ring
"Other"
Sealed Power Beast sunshell
SKF 29 element input sprag
Borg-Warner low/reverse roller assembly (late design)
Vamac 3 lip rear seal (prelubed)
Transtech paper & rubber (gasket) kit
Transmission filter (OEM)
Bushings (latest updates, including Teflon front pump & extension)
Thrust washer kit
Sealing ring kit
HD Bearing kit (Timken)
Borg-Warner Hi-Energy 2-4 band
Corvette servo
Trans-Go Performance Shift kit, with .500 boost valve & w/accumulation for nice part throttle shifts
All new molded pistons for forward, 3-4, & overrun
All new aluminum accumulator pistons
Old 12-05-2006, 12:02 PM
94z28L's Avatar
just a quick question, have you rebuilt a 4l60e before?
Old 12-05-2006, 12:08 PM
no built i am going to buy the kit and then have my mechanic do it
Old 12-05-2006, 12:28 PM
94z28L's Avatar
has he done one before? the 4l60e is a neverloving bitch to be honest and it takes quite a while to master building one to last
Quick Reply: tranny rebuild kits
