Ignition Cylinder Exchange
Just curious if anyone knows if the key code is anywhere on the cylinder itself? Need a new set of keys cut and the code doesn't match the VIN. Anyone done this swap that would know if the key code is on there? Should be a 4 number/letter code.
Also, anyone that has done this swap, do you have any tips? Looks like you have to pull the wheel?
TTT~~~ Anyone able to help me out here? Found out I do need to pull the wheel. But have read in other threads, that it is tricky to pull the wheel without messing stuff up. Any tricks tips help anything????
