trouble idling after cam install
i just got my tune done and im having some trouble still with my car. it has trouble finding its idle still...on a cold or hot start doesnt matter. i can start it give it a little help with some pedal and then it drops way down to 200 rpms then goes to 900 and stays eventually.
is it not getting enough air? i drilled a 7/32" hole in the throttle body, but i didnt mess with the screw. should i go bigger than 1/4" on the hole? i read somewhere youre not supposed to go bigger than that.
needs more tuning lovin'
bump the idle speed, add some timing, calibrate your base running airflow table, etc.
also, give us some more info. what your cam? got heads? what did you tune with? what was your process?
give us some details man!
Talk to Ed at Automotive Technology Inc., he was able to staighten out my cousin's 'vette' that had the same problem. He is very sharp with EFI and has reasonable rates. His # is 757-424-1740.
