ported 98 heads
Old 12-06-2006, 10:02 AM
john563's Avatar
Default ported 98 heads
I may be purchasing 98 ported heads in the for sale section here and wanted to know what gains to expect from ported 98 heads.
My mods are:
lid,slp maf,ported tb,ls6 intake,hedman LThedders,ory,dynomouth,TR224/112cam,and TCIssf 3500 stall
I put down 350 rwhp.
So what can i expect with ported 98 heads to this set up
thanks
john
Old 12-06-2006, 10:18 AM
2000WS6TA's Avatar
i wouldnt expect to much. 98 heads are junk, but ported they may help a little bit. id say no more then 15hp gain. hopefully someone else will chime in if im wrong.
Old 12-06-2006, 11:36 AM
trinijoee's Avatar
It depends on the ported heads & the tuner, my Cartek stage II 98 heads & cam in my 6-speed vette was dyno'ed at 399 RWHP. I have all the bolt-ons. I know others that had the same package and their dyno'ed results were similar. With an auto, it probably will be a little less. Ported 98 heads will flow better than stock LS6 heads, but it depends on the port work.
My mods are:
thanks
john
Old 12-06-2006, 11:49 AM
Studytime's Avatar
1998 heads ARE NOT junk. You could expect the same gains from 806 castings as you would expect from 241 castings- when both have been fully ported. The differences in port accuracy and surface finish will be removed by the porter, and the differences in flow will be zero. More important than the casting # (or year) is the quality of the port work.
I would suggest removing the stock 1998 valves from those heads, and upgrading to the later model LS1 intake valves and 5.3L truck exhaust valves. If your budget permits, aftermarket valving would be a good option.
Again, the 1998 heads are NOT junk. They flow less than the '01+ heads, but if you swapped the valves from the '98 to the '01 heads the flow improvement would be marginal.
There are several reasons the '01/02 cars ran better than the '98s in stock form. Cylinder heads is one item of a list comprising more important parts; better intake, more efficient exhaust manifolds, better catalytic converters, etc.
Ben T.
Old 12-06-2006, 11:52 AM
2000WS6TA's Avatar
Ben T.
well i guess its a good thing i wasnt the only one that responded. i didnt know the exact differences in the 98 and 01-02 heads i just knew the 98s werent as good.
Old 12-06-2006, 11:53 AM
Studytime's Avatar
Yep, if you have your choice in stock castings without port work... pick the 241 heads! Just like you were saying.
Once fully ported, it changes.
Ben T.
Old 12-06-2006, 12:37 PM
john563's Avatar
thanks for everyones help,but decided to order heads from TSP.I ordered them about an hour ago
Old 12-06-2006, 12:56 PM
GuitsBoy's Avatar
I have to agree with studytime here.
The 241s were SPM cast instead of sand cast which made for a smoother finish stock for stock.
Old 12-06-2006, 01:44 PM
prostock_bigblock's Avatar
patriot have a good deal on the 243s unported for 425$ asembled, they will out perform or will put similar numbers to a ported 806 and u still have the chance to port them in the future.
what heads did ordered by the way from TSP ?
Old 12-06-2006, 02:00 PM
Studytime's Avatar
Well, considering that ported set of ported 806 heads has 300 cfm potential vs. 260cfm from a stock LS6 head, I'm not sure that comment is valid.
Ben T.
Old 12-06-2006, 02:21 PM
Ben T.
we hava done a swap 3 years ago from a home ported 806 on a 98 car to a stock 243 , we lost 3 rwhp on the same dyno. and same weather conditions.
however, not all 806 well be ported to reach 300cfm.
These r some decent fully ported 806 #s
100 200 300 400 500 600
INT 72 153 217 258 284 289
EXH 42 107 145 182 207 216
after a couple of months we puuled the ls6 heads and took out the guides and did minimum port work and dynoed 19wrhp higher than the ported 806 set.
I used to have the dynos ,I will try to post if they r still available.
Old 12-12-2006, 03:17 PM
B18CYA's Avatar
my 806's were ported by Brian at High Tech Motorsports and made 398 rwhp 387 rwtq through a a4 so they are not junk
Old 12-12-2006, 03:43 PM
Studytime's Avatar
Was that without a cam? Can you tell us the specs on it?
Ben T.
Old 12-12-2006, 04:21 PM
B18CYA's Avatar
i would but then id have to kill you
no seriously though its with all the bolt ons in my sig
the cam is a compcams custom
226 @ .50 int
224 @ .50 ex
586 int
551 int
sorry guys no lsa though dont have the cam card
Quick Reply: ported 98 heads
