Pontiac GTO 2004-2006 - whats everyone doing for 16" D/R's
RADAR B8
12-06-2006, 10:21 AM
Ive got an 05 GTO that I want to run a 255-50-16 set of Mickey Thompsons but I need a set of inexpensive wheels to mount these to....any suggestions???
scot254
12-06-2006, 03:19 PM
I've got 16*8 T/A (I think 1998) wheels on mine, same tires as you.
Mines an 04, but I still doubt you would have brake clearance issues.
muff daddy
12-06-2006, 06:47 PM
just pickup 2 extra stock 17's and use those. some people have been using some 16in bmw wheels.
Rob
12-07-2006, 05:15 PM
16" F-Body wheels work fine in the back.
RADAR B8
12-07-2006, 05:20 PM
Id like to run 16s so I can get a slightly larger sidewall and not have to worry as much about the tires rubbing the lip of the fender like the 275 Mickey Thompson on a 17" stock wheel.
camaroonus
12-09-2006, 01:09 PM
but i thought the f body rims wouldnt fit on gto hubs?
Rob
12-09-2006, 01:33 PM
but i thought the f body rims wouldnt fit on gto hubs?Other way around. You need to dremel the GTO wheels if they are going on an F-Body.
Ytowngoat05
12-11-2006, 10:39 AM
bmw wheels work, friend of mine has a set of 15 inch rims with DR's on them...
MikeG
12-11-2006, 04:18 PM
They might fit on there ok, but they aren't the same bolt pattern.
The least that would happen is maybe screwing up the wheels a bit, the worst would be some broken wheel studs.
There are guys on LS1GTO that run them with no issues though. And personally, I wouldnt give a crap about screwing up some crappy 16x8 wheels anyway. You could just buy 2 more for like 50 bucks.
