Drag Racing Tech
Those with True Duals hows clearance loading on a car hauler?
Old 12-06-2006, 04:56 PM
2_wacko's Avatar
Default Those with True Duals hows clearance loading on a car hauler?
Hows the clearance going up and down a dovetail carhauler with True Duals? I need to know before I get them done thanks?
Old 12-06-2006, 05:01 PM
02SOMWS6's Avatar
my trailer is open in the center , no problems going on or off but not sure if you have a solid floor. I think you will have more issues not getting your front bumper cover to hit rather than the true duals. I have to use boards on my ramps to get the nose up enough so it doesn't hit going on and off
Old 12-06-2006, 05:34 PM
2_wacko's Avatar
I've loaded the car before no problems getting the nose up (dove tail) just worried about the duals.
Old 12-07-2006, 08:48 PM
6 & 8 Second Club
mrdragster1970's Avatar
Get a 2 X 12 and make some helpers, why take a chance.
I was lazy and didn't like jacking up the trailer.
Old 12-07-2006, 09:34 PM
cainsw's Avatar
My trailer is flat with no rear slope and I can load mine without hitting but it is very close. about 2 inches of clearance. I built my TD's and they fit as good and maybe better than my old Borla fit.
Old 02-13-2007, 06:07 PM
2_wacko's Avatar
Anyone else?
Old 02-13-2007, 06:17 PM
SLPSS99's Avatar
Drive on the new enclosed with no issues and my car sits pretty low.
Old 02-13-2007, 06:20 PM
SLowETz's Avatar
Real tight on a solid deck dovetail. My car is low also. Build some helper ramps to get the ramps/car at less of an angle to the trailer.
Old 02-13-2007, 06:30 PM
brandonppr's Avatar
I have tsp td and I have a simular trailer. they will rub if I dont put some wood runners to drive on to get it up high enough to clear.
I had mufflers off right off the headers and never had a problem but with the xpipe it is. I plan on going back to right off the collector before racing starts back.
Old 02-13-2007, 06:35 PM
Ls1LikeNoOther's Avatar
my buddys hawk is SLAMMED and he has true duals(that scrape everywhere) and i believe he has the stands for the rear of the trailer that prevent it from dropping when u load the car, and I believe that does the trick..
Because I know lots of cars bottom out on the trailer when u get to the point where the beaver tail and the ramp start sag towards the ground.
Old 02-13-2007, 07:07 PM
roadtrip120's Avatar
Not bad here, but i have 6' ramps with a 36" dove tail, and a lower deck height, than most fench trailers. The duals only scrape when the tires are flat (10psi) leaving the track m but not bad at all.
Old 02-13-2007, 08:04 PM
brandonppr's Avatar
I also have to do the same to keep my bumper from draging
Old 02-13-2007, 08:40 PM
Ego Killer's Avatar
no problems here
