knock sensors required?
are the knock sensors required for the genIII motors to even startup and run? I know the function of them and I'm not going to use them on my EFI swap to my genI motor. just need to know if the motor will function fine without them plugged in.
btw, I will be disabling all knock sensor codes within the tune file so the ses light wont be a problem.
thanks,
jake
thanks,
jake
thanks lol
I dont see either why I shouldn't run without em. I was thinkin about just disconnecting the ones in my truck, but talk about a PITA. thanks for the help, keep it comin
ok cool. I figured it shouldn't be a big deal. I use HPTuners so it'll be pretty easy to get it done right and for good. btw the efi swap is a custom ls-based MPFI system I'm building for the genI 350 in my sandrail. it'll be fun once it's all done
thanks again for the help
jake
jake
