LS6 would fit?
LS6 would fit?
I have a 98 SS camaro with the LS1. Do a LS6 short block would fit on my car? I know that I have to change the oil pan but my main doubt is about the engines accesories. Do them will fit as on the LS1; same place (alternator, a/c compressor, power steering pump, etc.?
ls6
Originally Posted by spy2520
yes, all the accesories should bolt up if you use your stock brackes,might not even have to change the pan since the blocks are pretty much the same externally. you could even put the ls1 heads on it if you run out of money...
