GM 847 cam needed!!
GM 847 cam needed!!
hey guys, i was just wondering where i can score a gm 847 camshaft for my 94 z28. Also what size rockers should i run with that cam?? thanks alot guys.
here is what it is going in. I picked this car up for $1000 dollars. Going to be a real good street/strip car. Its going to the body shop this weekend to get fixed and repainted.
Originally Posted by 383_LT1_1295
yup, i have a stall converter on order, although i havnt decided on what gears i should go with yet.
Originally Posted by dre2013
what stall did you go with? if you u have an a4, id go with 3.73s, if m6 id go with 4.10's
can anybody send me a link to a website that has a gm 847 cam?? i cant seem to find one anywhere. thanks alot
3.73's with an auto and 26" (stock size) tire won't trap you that high...if you're shifting around 6400 rpm..you will fall slighly short of that at the traps. a 27" tire and 4.10 gear would put you right there.
hell thats alot cheaper then what i thought. Should i go ahead and do 1.6 RR or 1.5? also, what type of lifters would be best for this application?
I have talked to a handful of tech guys and they all say that stock lifters will be fine. Might want to take a look at them and make sure the rollers are not worn when you pull it apart though. I went ahead and bought brand new stockers. Stay away from the infamous Comp "R" ones
