injector and spray question
Will I be ok on say 36lb injectors on a NA motor making around 470 then around 570 since its a wet kit and it add its own fuel. I was told that I wasnt really to sure about that. Any inputs on that. Thanks
By my calculations 460HP is 80% duty cycle, and 518 is 90% duty cycle, so you should be fine for now with 36# injectors.
As long as the fuel pump can keep up with demand you should be okay.
