Normal for VE Table to exceed 100%?
I added headers and a Balckwing . Went through it and did a VE/MAF tune. Some of the cells were in excess of 100%, (max 107%) @ 4400 and higher map readings.
In comparing my VE table with 2 other VE tables with headers/h/c, I noticed their VE tables topped out around 99%.
Questions is: Is it normal for modified motor to achieve >100% in VE tables?
Originally Posted by Rick@Synergy
yes, its normal. VE numbers are only numbers, just put them where they want to be.
Rick
Rick
Originally Posted by Chalky
Thought so. Just could not .understand why another car with same motor and better cam and heads would have a VE table that topped out at 99%! This was a tuned car as well.
This is because the other guy could have his IFR rate set differently than yours.
Rick
I think that is to high with just eaders. I never got them that high. Did u disable the MAF while VE tuning??? Did u use a Wideband and monitor your cammanded air flow to wideband???? After u set the PE to A/f u wanted??? If not that is y.
AFR WB was no richer than 12.6:1 and no leaner than 12.9:1.
FWIW, When I started to do my VE tune, the car went into limp home mode. I added 20% across the VE tables and started dialing it in from that point.
A lot faster with the mods Dave?
